(D2?) Quick Release hub?
05-08-2007, 06:32 PM
Hey boys,
To start with, my friends beautiful USDM S12 was stolen Sad This thing motivated me even more to getting a quick release hub, because its the best way how to prevent loosing your car. I can get a D2 quick release hub for a very very very low price, but I dont think it will fit :/ What do I have to do to make it fit? Is it even possible to make it fit somehow? If not, what hub will do fit?
and yes, I know I need a different steering wheel to Tongue
thanks a lot for your help!!
86ers.org
AE86 x GXE10
05-08-2007, 10:58 PM
Man that sucks!
Hope the car can be found back....
05-09-2007, 11:13 AM
Most quick release hubs bolt to a std momo-style hub. So you buy a steering wheel that has a momo-style 6-bolt pattern and the hub you need to bolt it into a corolla. Then the quick release just bolts in between the steeringwheel and hub.
Hope you understand this,
05-09-2007, 12:00 PM
NoHachi Wrote:Most quick release hubs bolt to a std momo-style hub. So you buy a steering wheel that has a momo-style 6-bolt pattern and the hub you need to bolt it into a corolla. Then the quick release just bolts in between the steeringwheel and hub.
Thanks Smile I thought that all you need is the quick rel. hub, now everything makes perfect sense Smile
As Sekiguchi said, I should really start using my brain sometimes Big Grin
86ers.org
AE86 x GXE10
05-09-2007, 03:24 PM
Also remember that most "cheap" snap-off hubs are about 7cm thick. That means the wheel will come 7 cm's closer towards you. Not a problem in my case (more of an advantage), but it might be a problem for shorter people that already sit close to the steeringwheel.
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 30,981 06-27-2018 11:15 PM
Last Post: Ryo
  Quaife quick rack totta Crolla 19 21,879 03-03-2018 03:32 PM
Last Post: Deuce Cam
Wink Hub size kazi 5 10,041 06-09-2017 10:06 PM
Last Post: kazi
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 19,075 12-21-2016 10:28 PM
Last Post: ditn
  Quick question - Brake Pad Dimensions Lt86 2 5,544 06-07-2015 12:08 AM
Last Post: jondee86
