DIY: Hopeless project.
04-20-2013, 06:55 AM
Hi all
This is a thread I decided to create for my car. It`s my first serious attempt at a "project" thread, so I`m sorry if aspects (Or indeed all of it, for all I care) is shaite, let`s just hope for improvement on my side As you will notice through the thread, I am working on a budget, and its not because I have a choice, it`s either do it this way, and shine it up properly as I can afford it, it`s either that or no dice what so ever.. This "build" (Well it nearly is a build because of the many things that my car lacks) nearly qualifies as a ghetto-job here in Norway, some of you might not understand why I`m doing things the way I do them, because you`re not used to the idea of owning and building a car like this on a relatively tight leash, welcome to `rolla building the way it goes with little money, whether you like it or not It`s a HUGE difference though, between those fancy and neatly (And absolutely amazing, might I add) finished builds featured on SpeedHunters, Driftworks, Youtube, Best Motoring and Hot Version and so forth. Only to find that setting someone to do the job can cost one a fair bit more than I can afford though (That does not, however, in any type, shape or form mean that you should avoid the workshops blablabla yadayada yeah you know..) Or that the perfectionism you envisioned is going to come at a cost more than you can actually support.. To put it into perspective: It took me half a year of working my ass off just to buy this car.. Just letting you know, I`m a complete newbie.. Anyway, upon getting the car and getting it running, I discovered that the engine needed a lot of work, weary TRD Gr.A bigport head on a stock ae86 block (The race block was blown some years prior to me buying the car) usually doesnt work that well. I originally wanted to restore the old 16v racing engine (Still working on that..) but changed priorities in order to get the car rolling, to let my first car ever stand still like this for years after hardly driving it was a shameful crime.. So last year (before I even got the drivers license) an awesome friend of mine offered his services and we went and picked up the engine that I had laying around at Underground Garage here in Norway, the owner (which is also the mechanic) who people started calling Mr.Toyota now (A most fitting nickname might I add) was plain awesome from the get go: From sourcing out the engine complete with wiring and everything from Japan, to getting to his garage directly from his main job and start work on the engine as I was on my way to pick it up, he`s also been troubleshooting and giving me mechanical tips ever since we first came in contact on the web! After a trip (and awesome conversation with Mr.Toyota) well worth the time, I could admire the new powerplant (Or sewing machine, depending how you look at it) With some modifications: You all probably know what he did already but for those who might be curious: Basically what "Mr.Toyota" did, was to dremel a port between the two water holes at the back of the head, therefore, as you can see, a lot of precious space between engine head and firewall can be saved by shaping and drilling your ordinary steel plate to use the 16v head- waterneck (Which most GTS people already has) instead of going for this alternate (And probably just as good)solution: (Picture off google-images) I`m schizo about ending up with something that doesnt fit, I wanted as much firewall clearance as I could get, so thats that! Then I later got the necessary parts from Underground Garage (The parts were not there yet when I was there to pick up the engine itself) Picked up the wiring loom as well but thats in the bin which is barely visible at the top of the pic. . All of you probably already noticed the A/T ECU, this is because the 6spd M/T ECU which somehow many people opt for, especially in U.S it seems, has an absolutely apeshit ignition curve in order to save the puny 6 M/T internals, couple this with the fact that the 20v is already hard enough to get running well with stock ECU in FR layout, I decided that sacrificing the few hundred RPM`s but increased driving time in place of added crappy troubleshooting (Will probably get enough of that as it is anyway) was not a bad idea. vague rumor also has it that the A/T ecu gives more punchy accel-response, though we`ll see about that The OEM 20v wiring loom was already customized by "Mr.Toyota" to suit AE86/RWD application, I do not yet have the guts to do splicing into OEM wiring on the car though (And since the car was used in all sorts of competition prior to me acquiring it, it had no OEM engine loom left either).. So to "MAKE CERTAIN" in terms of proofing the setup from myself, I ordered a self-sufficient 20v wiring loom from Tweakdperformance (Who, might I add, has been with me every step during the electrics part so far and guided and explaining me the connectors I didnt know, plug by plug!) As for solution to the distributor problem and other tid-bits all of us RWD guys have to face when tailoring these engines for RWD use (Minus the TA60 owners, they can slam the engine w/dizzy cap straight in...), I had a chat with an Australian guy named Samuel who`s almost as crazy as Mr.Toyota @ Underground Garage here in Norway, his shop`s called SQ-Engineering, and hes done a remarkable quality job at designing and producing RWD parts for 20v 4AGE`s for quite some time now. So, along with stuff I already had accumulated over the years, I took off the Wrong Wheel Drive stuff (Sry FWD fans..) and started assembling it to RWD-specs: This is the most cost-effective solution I could think of, it took only about 3 months (!!) of waiting for the announced kit to be designed, developed, tested AND produced in quantity (And quality might I add), and sent to me, but I`m convinced it will have helped me out in the long run, my goal is to get a good WORKING engine (Not necessarily a good RUNNING engine) to cope with the sometimes stressful environment up here in the mountains. Basically I`m doing everything I can do get daily-driver reliability, so I can spend less money on mending problems, and more money on shining things up later on Sure, I wont get the possibly added 5 horsepower of simultaneously firing COP`s, but from the thousands of forum threads I`ve read by now I do know I have a good chance of better (better, NOT perfect, an OEM performing 20v on stock ECU, adapted for RWD is NEVER an easy task even for the most professional workshops) function and reliability in a sometimes a little too harsh driving environment, so it`s nice to have OEM troubleshooting manuals to fall back to when everything else fails, and that usually works best if things are as close to OEM specs as possible.. Enough about that, assembly continues: Here with distributor installed, topped of with SQ-Engineering slim dizzy cover (Again, no chances taken): Installed flywheel (MR2 200mm) with ARP bolts (Not taking the possible chance of getting my feet blown off by reusing old flywheel bolts no matter what anyone says) and ACT round-clutch (The sharp 20v 4age is already enough to handle in the intersections) plus I`d rather a 50-100 euro clutch buys the farm than a hard to get T50 tranny.. Then I encountered a interesting problem, the 20v oil filter sandwich wont do because of the RWD exhaust manifold (would crash with the filter) Mr.Toyota adviced me that certain early 4A blocks come with a shorter union bolt, so I had a look at the stuff I had laying around, and sure enough... (Btw, take a look at that no-name filter, I think we can surmise why that block stopped swiveling ) Here installed on 20v (Along with lightened 16v engine mounts): So, as we say here, the shit started coming together (This is a few days ago): I bought the JDM T50 tranny w/TRD quickshift from fellow ae86 mate and PowerDrift driver "EGR" who, as he pretty much told me "Saw what the 4AGE could do and bought a F20C instead" lol, but in his defense, he had two engine break downs with just 4 trackdays.. So anyway, shit started coming together fast, too: Now you`ll see why I`m glad I made sure when buying the parts: The dizzy cap clears the firewall with a little margin to spare, no need for any "massage", I am just sick and tired of constant problems coming up, especially if I can do anything to prevent that, this car taught me that early on in the process so SQ-E water outlet seems to not fit because the 6mm cooling tube for the 16v manifold (I think thats what the 6mm tube does?) is in the way: But then again, no need for that, easy solution: Chopped off the tube clamps and blocked the hose.. I also had to chop the main tube and use a hose so I could get clear of the knock sensor So as you know by now, I`m using all the 16v cooling routes, and also 16v alternator and 16v main pulley. Further progress: Started fitting the wiring loom (And pulled it through existing hole in the firewall), I also grinded the alternator bracket to clear the dreaded 20v tensioner assy. And since I`m using 16v waterpump (So I can use the 16v alternator, no need to rewire anything) I had to file and grind that to clear the tensioner wheel as well (Will upload pic of that tommorow) Plus I`m doing an experiment, it`s starting to look like spring time now, in a bid for performance oriented experiment I`m heat wrapping the radiator and heater hoses (as well as exhaust, naturally) to see if that will save me the trouble of spacing the hood off the hinges and get cooler air intake temperatures for a little bit more performance (At the weight expense of a few grams worth of heat wrapping) Furthermore I assembled the fuel delivery system: From main fuel tank, through Facet Red Top Competition fuel pump, in this case used as lift pump, and into the 2 Litre catch tank, from the catch tank, through subaru impreza fuel filter and straight through the coupè and out through the passenger side firewall and to the engine bay. And yes thats a KE30/35 tank (I think) in the luggage compartment lol, I guess it beats a small 20 litre or w/e and massacre the spare tire-well? It worked for competition, will work for street driving+ a few track days per year too Now here is an interesting problem: This has got to be the most idiotic driveshaft crossmember fastening solution I`ve ever seen to date. Sure, lirking a bolt with a nut up into the mounting point there if you have no proper bolts will work, but what about when you have to take the shaft off?? I had to ponder this problem for a while, and while my mind was about to come to the conclusion of splitting the nuts with a dremel, I had another idea: I sliced the bolt face with the Dremel instead, this way, I could use a ratchet spanner to take the nut off, while holding a flathead screwdriver still on the slice on the bolt-face: Forgive the dark pictures, but when you`ve got a big dark ex-cowfood silo to work in and limited tools, you make do with what you have.. Anyway, as you can see, the ratchet spanner can be used to screw the nut off whilst holding the bolt-face still with a flathead screw driver Voilà: And since laying on hard wood plates under a car that is barely off the ground is VERY physically demanding (And if you think you are strong as heck, try working under a car just 45-55cm off the ground..) I quickly switch between tasks on this car so that while waiting for something or tired or working on the same thing over and over, I can constantly get things done and achieve progress, even being just one person working on the car My attention to the interior side of things late 2012: I managed to actually take off the rally instrument board, then set about removing the rally instrument wiring. To my surprise, the original OEM instrument wiring and terminals was still there! So, to me the dream was always to install a hard and expensive (For me anyway) OEM EDM Zenki instrument cluster (In keeping it with the cars originality, since everything else is so frankensteined) The awesome and crafty member Jamiesmirror on these forums (We have stayed in daily contact on MSN/Skype for years now!) sourced one up for me, and it wasnt long before he, despite moving to a different country, sent me the goodies, here its mocked up and tested: But it looks cooler in the dark: Thx Jamie!! As you probably know, looking at existing wiring jobs so far, the car I bought was not exactly perfect before I bought it.. As for figuring out and getting rid of this circuit salad: You`ll just have to wait and see! Stay tuned! 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
04-20-2013, 11:50 AM
Very nice build mate.
Sam really does make some nice parts huh? Keep up the good work! Aram. |
04-20-2013, 12:07 PM
Damn.. nice setup!
I need more time to read evertyhing you got there! And the 20V.. beast! |
04-20-2013, 02:44 PM
You could put a little less emphasis on the being poor bit, a few exceptions aside, most AE86 owners are no lottery winners, that's how we ended up with them in the first place.
Seems like you have an interesting project though, doesn't seem hopeless to me. FABRICA MI DIEM, PVNC! |
04-21-2013, 03:51 AM
Quote:You could put a little less emphasis on the being poor bit, a few exceptions aside, most AE86 owners are no lottery winners, that's how we ended up with them in the first place. Don`t take this the wrong way, I mean no offense: I could have easily gotten a 300bhp S13 or pristine 280ZX for less than what I bought this car for, at the time, not sure how things are in other european countries but judging by your statement I think it`s obvious that the Norwegian JDM market doesnt fall under the usual norm Walk around with clothes that are only hand-me downs exclusively, live on minimum existence, no parties, no afternoon beers etc etc for 3 years, for the sake of a Corolla, thats my "emphasis" whether you like it or not By hopeless I don`t mean that the car cant ever be fixed, otherwise I would never have bothered to install this engine, by "hopeless project" I mean it`s the ambition I have for the car. Thanks a lot for your constructive feedback though and I`ll keep the "poor" stuff at a minimum Anyway: With the relay rack removed I saw that only two relays were actually in use, probably for the head-lights, for now I put female connectors on those wires and zip-tied the two remaining relays in place. @ Aram, yeah Sam`s parts seem to be of high quality Onto the stuff I promised I`d post, it`s more like a little technical segment, as I havent seen too much material on this online (Had to ask people to find out how to do it..): Here`s the alternator bracket grinded to get clear of the tensioner assy, if you dont do this, the alternator pulley wont be alligned with main pulley and water pump pulley, needless to say the consequences.. Heres the 16v waterpump: Grinded to clear the timing belt tensioner wheel, here`s a pic of a normal 16v waterpump, I took my time with this and used a Dremel grinder tool and a hand file, constant test-fitting and patience is the key. Notice how it`ll look like when not grinded (Circled area): Here`s a spot on the block you have to file/grind a little too: It`s that brownish cast iron bolt-eye bracket on the engine block, for the waterpump housing. A better pic, Sam-Q shared the link for me on the 86DC forums: It`s the bolt-eye protrusion just above #4 (Taken from another article I think) You have to grind on the underside, otherwise the waterpump housing wont fit straight on the block, and you`ll have a waterleak.. Also remember, dont use FWD seals where the pump housing meets the inlet @ #4 in that picture, the entire pump assembly will build out towards the timing-belt and tensioner wheel, and you wont ever be able to fit your 16v waterpump.. Use an O-ring that fits the inlet hole groove, and smear it with axle-grease instead, put it in place in the groove around that inlet hole, then put waterpump assembly on and bolt it in place. Now I`m stuck on two things here.. The harness main connector on the loom needs a key-turn 12v source.. I put a female cable shoe on a wire and put it on the 12v shoe on the main connector, but on the ignition lock assembly behind the key (Which I also had to replace, and got cheap from Ebay, look for CS177 from Borg Warner or Beck Arnley), I`ve forgot which one of the wires is constant power.. I know that black with white stripe is for starting but I have no idea about which of these originally gives 12v power to the main loom connector: Brown, Brown with red stripe, black with red stripe or blue with red stripe... Does a kind soul with a better memory than me have input to this? 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
04-21-2013, 11:27 AM
White should be the colour of almost all constant 12V sources in the car.
If we're talking about wires going to the ignition key : -Blue-red is ignition switched accessory 12V -Black-orange is the trigger for the engine main relay. -Black-Yellow is switched 12v to ECU, wipers, turn signals and gauge. -Black-Red is the constant 12V source for the engine main relay. -Black-White is the starter signal as you already know. You can find this stuff out yourself by downloading the AE86 electrical manuals from the aeu86 home page, they are really a great help when doing electrical work. About my comments on the poor business: I bought my ae86 when I was 20 years old, back then it cost me 550 euro's. I think it's a travesty what some people are asking for rusty old shitter 86's these days, but if there's a market, then who is to blame the sellers? Doing everything yourself out of necessity (which I also do) can inspire hopelessness in the best of us, but if anything it teaches you some skills. The most important thing is to not bite off more than you can chew. FABRICA MI DIEM, PVNC! |
04-21-2013, 11:58 AM
You are absolutely right!
Thanks a lot for the educating info there Ivan, I couldnt find it from the manual even if it was about life and death And can I just say KUDOS to anyone with ANY understanding of those riddle charts called ""ae86 manuals"" with diffuse (at best) references to contact/plug/pin points, wire colours and so forth Took Jamie just 1 minute to figure it out though, he must be a true scholar! From what he figured, the speed signal pin is pin no.14 (From the left) on white connector for the cluster: (B means instrument cluster terminal connectors.) And goes to, according to 20v manual (bt8-fi.pdf on aeu86 home) the black 22-pin Terminal on pin.no 3 at the ECU (This is the kind of manual I like): See, I can do it if its not written in ancient riddles! Theres also an issue figuring out the vacuum system, I`ve connected diafram (Sorry, couldnt find the correct English spelling) with vacuum nipple at #4 throttle body, with two one-way valves in between, but thats pretty much where progress stopped. When I got the engine, most of the lines (Minus EVAP and Diafram) was not connected to the vacuum rail anyway so thats why I`m having trouble re-connecting everything, when theres no references to the original setup on this engine. I promise, if I EVER get this vacuum stuff straight and running well, I`ll write a technical on it! Btw, nice Ivan, you got your ae86 about 10 times cheaper than mine, and 2 times cheaper than my daily driver, market and demand really impacts the prices! Let`s just forget about the whole thing let it be about the car, everyone makes do with what they got anyway 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
04-27-2013, 07:41 PM
Gotten a little closer:
Now I need to figure out where to put a few wires, as usual the wiring diagram is a pita to even attempt to figure out where to plug tacho, water and oil pressure and check-engine light on instrument cluster, +fuel pumps on ignition, so thats going to take another week if I`m lucky.. 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
04-28-2013, 07:59 PM
And of course when connecting battery to test basic electronics again, instrument cluster has no backlight to the gauges (Though it worked earlier).
Heater fan doesnt work either (Though it worked earlier) And signal lamps blink about 10X faster than before (@ ronski-speeds) See what I mean about hopeless project? This is getting old... 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
04-29-2013, 11:12 AM
trumpets of your admission seem quite short, what lengths are they?
