DLI GZE no spark
04-10-2011, 08:34 PM
DLI GZE no spark
My map DLI GZE has a no spark issue, it ran last year set up the exact same way, last night I re-assembled everything and when I turn it over it sputtered a couple times and that was it, ajd then no spark... I've checked for power at coils, ignitor, ECU.. Everything checks out....
Tried a spare coil I had, ECU and cam angle sensor and no luck, engine is getting fuel as it's soaking the plugs, I've run out of ideas on what to check anymore
04-10-2011, 08:42 PM
DLI GZE no spark
If power is OK and your spares dont work I would start to look at the ground points.
04-10-2011, 09:08 PM
DLI GZE no spark
Ive already took a booster cable and hooked it up from the battery straight to the engine... still nothing
04-10-2011, 10:27 PM
DLI GZE no spark
Get a new set of plugs (cheapest copper core that meet specs) and try
them. Make sure the igniter is firmly grounded.
Cheers... jondee86
02-01-2013, 07:05 PM
DLI GZE no spark
jondee86 Wrote:Get a new set of plugs (cheapest copper core that meet specs) and try
Cheers... jondee86
suppose i should update this in case someone has the same issue, turned out after all it was the plugs, when we took the line off the plug and grounded it out it was fine, spark just wasnt getting through the plugs, even though they hadnt even had 2 hours of run time
  Weak spark, doesn’t start. AlexFourTwenty 4 18,954 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
  20v no spark & dry plugs. Rascal21 26 45,074 05-10-2013 02:47 AM
Last Post: Rascal21
  Spark Plugs on modded 16v apardal 1 5,049 03-15-2012 08:14 PM
Last Post: apardal
  GZE Swop with PAS & AC Lauren 12 18,502 02-16-2012 01:04 PM
Last Post: heshan
  Engine sounds slush GZE with VIDEO ! Okami 13 19,568 01-03-2012 12:12 PM
Last Post: Okami
