Damn rust
09-07-2005, 11:45 PM
Damn rust
Hey guys, can you guys give me suggestins what to use and how to fix this? I have body filler lying around, dont know how to use it though. I fyou guys could give me tips or directions on what to do, since i bet some of you have this problem as well..
thanks in advance Sniper ----------------------------- 1986 Toyota Corolla SR5 1989 BMW 535i 1986 Volvo 740 GLE ----------------------------- |
09-08-2005, 12:14 AM
Damn rust
remove the rust thats first prior than you can redo it with primer (not yet full paint jobs) until you get the car respayd.
Removing rust will be either euhm grind it off and when you find holes replace the metal. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
09-08-2005, 01:23 AM
Damn rust
I know about painting cars, no experience though. I have rust treatments, theres a hole behind the front left wheel, about 1.5 cm wide... body filler time? or put a piece of metal over it?
09-08-2005, 02:06 AM
Damn rust
With such a small hole I imagine you can just use body filler. Just remember to take your time and make sure you grind/cut off all the rust in that area. If you do a half-assed job, the rust will only come back.
Good luck! Trueno for sale! |
09-08-2005, 05:13 AM
Damn rust
Heres that stupid hole...
09-08-2005, 09:27 AM
Damn rust
Grind off all the rust, especially clean the swiss-cheese like bit around the hole. Dont forget that panels have 2 sides, or it will just start rusting from the back again.
Once it's cleaned immediately apply a rust treatment (rust converter), because blank metal will start oxidating the second it's clean. Then apply filler and a good coat of acid primer. This is just the amateur botch-job way of doing things, but if you had the cash to have this done professionally you wouldnt be asking us now would you. FABRICA MI DIEM, PVNC! |
09-08-2005, 09:48 AM
Damn rust
Body filler will be pretty useless, if you do it with body filler, it will be a short fix... your rust is for cut &replace, and asap... looks like a lot of work on your car....
09-08-2005, 10:39 AM
Damn rust
Yeah, I would try to find a mate that can weld and has some body repair experience. Cut out the rusty bits around that hole and weld in a new plate so no rust is left behind.
The other bits you should grind down so the rust is completely removed and then treat the bare metal with some acid primer to stop it from rusting again. Then take a look at how much metal is left behind and if its filler time or if those bits turned out to be worse then expected and its also welding time.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
09-08-2005, 12:14 PM
Damn rust
Remove that nickel wheel cover and then remove rust :wink:
danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
09-08-2005, 12:57 PM
Damn rust
nmwisima Wrote:Remove that nickel wheel cover and then remove rust :wink:As far as I can see it does not look like a cover... But I don't think removing his wheelcovers are part of the subject, so please back on topic. 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
Rust in trunk | AnthonyStallone | 11 | 13,536 |
02-18-2015 06:23 PM Last Post: Bean |
Rust removal | totta Crolla | 9 | 9,025 |
02-02-2009 10:27 AM Last Post: S.K. |
Fixing fenders? Rust protection? | Bubble_Drift | 2 | 3,595 |
01-03-2008 05:58 PM Last Post: LarsZ |
Rust repair (fixation) – how to do it right ? | Ryo | 8 | 23,029 |
10-16-2007 12:29 PM Last Post: Ryo |
1st rust sighting inside and some distortion | faz | 17 | 16,097 |
05-25-2007 10:42 PM Last Post: faz |
