Dash Lights
09-08-2017, 09:24 PM
Dash Lights
Hi all.
Some might remember that I had an issue with my dash light and a few suggested that the 'dimmer' might be down or a bad earth... well I've been at its and still nothing... My Trueno is GT and doesn't come with a dimmer. I have also earthed every wire on the headlight switch and everywhere on the 2 block connectors that attach to the speedo. I've also gone as far as taking the green circuit bit where the bulbs plug into on the rear, Off, and clean up the earth points. Still nothing. Anyone have any other ideas or is it time to try different clocks incase mine are done? Cheers! |
09-11-2017, 09:05 AM
Dash Lights
Have you inspected the flexible circuit board behind the cluster? Sometimes traces burn out...
09-11-2017, 09:14 AM
Dash Lights
I also had the problem once that where the connector attaches to the circuit board, there were small cracks in the circuit board (where it does the 180 degree bend) and also that the connectors themselves were not as tight as the could have been. In my case it was the pwr / eco lights that were not working.
09-12-2017, 10:04 PM
Dash Lights
Yes have taken off the green flexi film and looks in order. The connectors are tight on mine. I don't have an eco/pwr light on mine so that's that haha. I'm fresh out of ideas. Might try new cluster and see. At least I'll know if it's the cluster or not.
Digital Dash | evfan42 | 190 | 269,933 |
05-03-2024 06:44 PM Last Post: banpei |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 8,825 |
12-19-2021 11:58 PM Last Post: gh0st |
Dash Waning Lights | pack | 7 | 4,684 |
10-06-2021 01:00 PM Last Post: pack |
Trueno Digital dash kph to mph | Bojack | 3 | 7,322 |
11-21-2018 12:27 AM Last Post: kazi |
Custom Dash Cluster | kazi | 14 | 21,079 |
10-24-2017 09:05 PM Last Post: kazi |
