Diagnostic port
04-24-2010, 05:23 PM
Diagnostic port
Hey guys.. Where is the diagnostic port where I could connect the laptop to find out the Error Codes?
If anyone could help me out that owuld be Great! thanks, Heshan. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
04-24-2010, 06:15 PM
Diagnostic port
It is on the firewall, but you can not connect it to the laptop.
Check the codes from here: http://www.troublecodes.net/Toyota/ # Before proceeding, make sure the: * CHECK ENGINE light circuit is functional. It should be ON when the ignition switch is ON with the engine stopped. * Battery voltage is above 11 volts. * Throttle valve is fully closed (Throttle Position Sensor IDL points closed). * Accessory switches (A/C, etc.) are OFF. * Engine is at normal operating temperature (if possible). # Turn ignition switch to ON position. * Do not start the engine. * Place a jumper wire across TEl and El terminals in engine check connector. # Count number of flashes from CHECK ENGINE light. * If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously and evenly about 2 times a second. # Otherwise, the light will blink a number of times equal to the trouble code as follows: * The light blinks only (.5 second ON, .5 second OFF) when indicating a number. * The light will be OFF for 1.5 seconds between the first digit and the second digit of the code. * If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed. * Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat. # The diagnostic code series will continue to repeat as long as the check connecter terminals TEl and El are connected. # When finished, remove the jumper wire. # After repairing the malfunction, clear the codes from the ECUs memory. ![]() "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
04-25-2010, 12:55 AM
Diagnostic port
Or you can stay on aeu86.org, and download the factory diagnostic manual!
http://www.aeu86.org/index/technical-ae8...topic=5158 ![]() |
04-26-2010, 03:33 AM
Diagnostic port
a great help!
04-27-2010, 04:10 AM
Diagnostic port
-=Trueno ae85 SR 3a-gze=- |
Small Port Swap | Alex170984 | 1 | 4,352 |
11-21-2016 01:46 PM Last Post: Alex170984 |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,509 |
10-25-2016 09:18 PM Last Post: oldeskewltoy |
Help! Diagnostic connector (IGN) for dataloging with MS? | Bean | 2 | 4,557 |
05-24-2011 11:07 AM Last Post: roman |
4age intake side (port) dimensions | Uzelac | 15 | 36,303 |
03-03-2011 12:43 AM Last Post: Uzelac |
small port engine | totta Crolla | 4 | 6,034 |
07-03-2010 10:05 PM Last Post: totta Crolla |
