Diagnostic port
04-24-2010, 05:23 PM
Diagnostic port
Hey guys.. Where is the diagnostic port where I could connect the laptop to find out the Error Codes?
If anyone could help me out that owuld be Great! thanks, Heshan. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
04-24-2010, 06:15 PM
Diagnostic port
It is on the firewall, but you can not connect it to the laptop.
Check the codes from here: http://www.troublecodes.net/Toyota/ # Before proceeding, make sure the: * CHECK ENGINE light circuit is functional. It should be ON when the ignition switch is ON with the engine stopped. * Battery voltage is above 11 volts. * Throttle valve is fully closed (Throttle Position Sensor IDL points closed). * Accessory switches (A/C, etc.) are OFF. * Engine is at normal operating temperature (if possible). # Turn ignition switch to ON position. * Do not start the engine. * Place a jumper wire across TEl and El terminals in engine check connector. # Count number of flashes from CHECK ENGINE light. * If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously and evenly about 2 times a second. # Otherwise, the light will blink a number of times equal to the trouble code as follows: * The light blinks only (.5 second ON, .5 second OFF) when indicating a number. * The light will be OFF for 1.5 seconds between the first digit and the second digit of the code. * If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed. * Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat. # The diagnostic code series will continue to repeat as long as the check connecter terminals TEl and El are connected. # When finished, remove the jumper wire. # After repairing the malfunction, clear the codes from the ECUs memory.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
04-25-2010, 12:55 AM
Diagnostic port
Or you can stay on aeu86.org, and download the factory diagnostic manual!
http://www.aeu86.org/index/technical-ae8...topic=5158 |
04-26-2010, 03:33 AM
Diagnostic port
a great help!
04-27-2010, 04:10 AM
Diagnostic port
-=Trueno ae85 SR 3a-gze=- |
| Small Port Swap | Alex170984 | 1 | 5,020 |
11-21-2016 01:46 PM Last Post: Alex170984 |
| Small Port 10.3 Pistons | Alex170984 | 1 | 5,181 |
| Help! Diagnostic connector (IGN) for dataloging with MS? | Bean | 2 | 5,080 |
05-24-2011 11:07 AM Last Post: roman |
| 4age intake side (port) dimensions | Uzelac | 15 | 39,485 |
03-03-2011 12:43 AM Last Post: Uzelac |
| small port engine | totta Crolla | 4 | 6,857 |
07-03-2010 10:05 PM Last Post: totta Crolla |
