Diff ?
06-25-2007, 04:22 PM
Diff ?
Ok I have a 85 AE86. The diff is wining alittle, I wanted to know if you can change the oil back there and if you can how to do it? Thanks for any and all help.
06-25-2007, 05:11 PM
Diff ?
yes you can change the oil. You have to check whether u have an LSD diff or not(you need that info, buying diff oil).
Philip
06-25-2007, 05:28 PM
Diff ?
lift your rear up and turn the wheels, if both wheels turn in the same direction you have an lsd....
06-25-2007, 05:39 PM
Diff ?
I have LSD, I know that cus when i burn out it spins both wheels
06-25-2007, 05:42 PM
Diff ?
How do you swap out the oil?
06-25-2007, 06:20 PM
Diff ?
there's a tap under the diff. Warm up the diff oil by driving, this helps to drain the oil. you fil the diff through the level check plug.
Philip
06-25-2007, 06:55 PM
Diff ?
Changing the oil rarely ever cures ring and pinion whine.. but it's worth a try.
Too much burnout's and clunky drifting will do that to an old ae86 diff..
06-25-2007, 07:37 PM
Diff ?
Sorry to use this topic, but i have some similar problem. My ring and pinion arent perform correctly. Theres some backlash when driving in low rpm´s and changing gears, when on full gas, seems good. I was wondering if a new spacer "virtually" fix my problem. I mean virtually, assuming that ring and pinion are in reasonable shape.
[Image: AEU86 AE86 - Diff ?]
Cump´s
Filipe Oliveira
06-25-2007, 09:55 PM
Diff ?
You might be better off re-checking the adjustment of the ring and pinion before you get yourself a new spacer.. installing a new spacer means disassembling a lot of the pinion assembly. If it's not aligned correctly, then a new spacer wont help either.
06-25-2007, 11:54 PM
Diff ?
Yes I suggest to re-check the ring and pinon backlash.
Check the pinion preload and you will know if you need to change spacers(in 90%+ of case no!)
After check carefully the contact path and you should be good.
Also for lsd diff I highly suggest Silkolene BoA90 ls oil.
I have compare it with many hypoid oil and this one is the winner in every spec.
  What Diff Oil For a Clutch plate diff? jamieae86 10 14,404 12-16-2011 11:14 AM
Last Post: bakonick
  weight diff head diff center fax0815 5 6,842 12-21-2010 03:03 PM
Last Post: fax0815
  Celica F-diff with Hilux/ Pickup Torsen diff Roye 7 11,594 04-29-2008 09:13 PM
Last Post: Roye
