What Diff Oil For a Clutch plate diff?
12-06-2011, 02:11 AM
what oil should i use in my clutch plate trd 2way , its macking a clacking noise when turning , diff is 100percent, what oil could reduce this noise?
comma 80w/90
castrol b373 ?
any advice welcome thanks
12-06-2011, 04:15 AM
I run Motul 90PA with no problems on my TRD, Castrol SAF-XJ works also well with clutch lsdĀ“s.
Castrol b373 does sound right, too Smile
Do you know which oil is in your diff right now?
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
12-06-2011, 10:17 AM
I run Castrol SAF-XJ for three years now, no problem.
Any 75W140 for limited slip should do.
12-06-2011, 02:43 PM
im not sure what oil is in it, i was also recomended silkolene boa 90ls anyone have any info
12-06-2011, 07:25 PM
on Driftworks some guys recommend this oil for clutch-plate diffs
it's for Racing differentials
Redline Lightweight shockprove
http://www.redlineoil.com/product.aspx?pid=43&pcid=8
there's also a friction modifier you could try adding to your current oil
12-06-2011, 09:06 PM
Castrol SAF-XJ or Redline Lightweight shockproof (reduce the noise significantly)
But if you have a really noisy "clack" you should rebuild it.
I don't know what you do with your car, but when you're drifting it's recommended to rebuild your LSD every year or so.
12-07-2011, 04:37 AM
Is this a brand new diff? You need to do the break-in figure 8's if so, which will quiet down the chatter quite a bit.
Andrew
12-09-2011, 09:15 PM
MOTUL 90PA with My KAAZ 2 ways LSD
(80W/90 GL-5 recommended by kaaz) : http://www.kaazusa.com/techhelp2.html
12-16-2011, 11:14 AM
best oil for differential are the motul 75/150
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
sorry 75/140
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 57,957 11-18-2022 02:19 PM
Last Post: FanIsHere
  trans oil, lsd oil change Apolan 9 17,609 10-01-2014 03:57 PM
  Spindle dimensions, backing plate bolt pattern Rascal21 18 22,501 03-13-2014 11:45 AM
Last Post: Rascal21
  Oil cooler -> low oil pressure Jan Pedersen 24 31,835 06-06-2013 07:36 PM
Last Post: Deuce Cam
  Urgent replies needed DIFF OIL + refresh Okami 6 6,817 06-17-2012 09:56 PM
Last Post: Okami
