What Diff Oil For a Clutch plate diff?
12-06-2011, 02:11 AM
what oil should i use in my clutch plate trd 2way , its macking a clacking noise when turning , diff is 100percent, what oil could reduce this noise?
comma 80w/90 castrol b373 ? any advice welcome thanks |
12-06-2011, 04:15 AM
I run Motul 90PA with no problems on my TRD, Castrol SAF-XJ works also well with clutch lsdĀ“s.
Castrol b373 does sound right, too ![]() Do you know which oil is in your diff right now? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-06-2011, 10:17 AM
I run Castrol SAF-XJ for three years now, no problem.
Any 75W140 for limited slip should do. |
12-06-2011, 02:43 PM
im not sure what oil is in it, i was also recomended silkolene boa 90ls anyone have any info
12-06-2011, 07:25 PM
on Driftworks some guys recommend this oil for clutch-plate diffs
it's for Racing differentials Redline Lightweight shockprove http://www.redlineoil.com/product.aspx?pid=43&pcid=8 there's also a friction modifier you could try adding to your current oil |
12-06-2011, 09:06 PM
Castrol SAF-XJ or Redline Lightweight shockproof (reduce the noise significantly)
But if you have a really noisy "clack" you should rebuild it. I don't know what you do with your car, but when you're drifting it's recommended to rebuild your LSD every year or so. |
12-07-2011, 04:37 AM
Is this a brand new diff? You need to do the break-in figure 8's if so, which will quiet down the chatter quite a bit.
Andrew |
12-09-2011, 09:15 PM
MOTUL 90PA with My KAAZ 2 ways LSD
(80W/90 GL-5 recommended by kaaz) : http://www.kaazusa.com/techhelp2.html |
12-16-2011, 11:14 AM
best oil for differential are the motul 75/150
1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
sorry 75/140
Mocal oil cooler & sandwitch plate ordered | Gtsi-R | 48 | 53,781 |
trans oil, lsd oil change | Apolan | 9 | 16,510 |
Spindle dimensions, backing plate bolt pattern | Rascal21 | 18 | 20,761 |
03-13-2014 11:45 AM Last Post: Rascal21 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 29,523 |
Urgent replies needed DIFF OIL + refresh | Okami | 6 | 6,292 |
06-17-2012 09:56 PM Last Post: Okami |
User(s) browsing this thread: 15 Guest(s)
