Diff overhaul
01-14-2006, 02:27 PM
Diff overhaul
I’m planning to do diff overhaul these days, does anybody know oil seal spec?
AE86 rear end bearing kit includes the following:
pinion nut
[color=red:23edc5a81a]oil seal ???[/color:23edc5a81a]
pinion bearing front
pinion bearing rear
crush sleeve
carrier bearing x2
pumpkin gasket
Fun is not the straight line!
01-17-2006, 12:52 PM
Diff overhaul
I’ve just ordered from Toyota:
pinion nut
oil seal
crush sleeve
diff gasket kit
The cost is around 30€ for all.
I bought bearings separately.
01-17-2006, 01:29 PM
Diff overhaul
have you got part number???
[Image: AEU86 AE86 - Diff overhaul]
Koukis - Red, Silver/Gray,
01-17-2006, 02:28 PM
Diff overhaul
dAYTONA Wrote:have you got part number???
Here you are, diff part numbers.
01-23-2006, 05:02 AM
Diff overhaul
Thanks.
01-23-2006, 09:46 PM
Diff overhaul
I rebuilt my diff unit a while ago, which was fairly straight forward to do, but what wasnt very easy was setting the backlash and pre-load etc! Took hours and hours to get it right!
01-23-2006, 09:51 PM
Diff overhaul
is this the same set off parts for zenki and kouki diffs?
http://www.86ers.org
01-24-2006, 12:16 PM
Diff overhaul
SekiguchiUeno Wrote:is this the same set off parts for zenki and kouki diffs?
The safest way is to give them your VIN. You will not make a mistake with part numbers. I did like that.
01-30-2006, 12:07 AM
Diff overhaul
2 Black betty: How did you adjust backlash and pre-load?
Got any advice?
1984 AE 86 Levin hatchback
1989 AE 92 GTi
2004 Kawasaki KLE 500
01-30-2006, 10:03 AM
Diff overhaul
Do a search Kas, there is a lot of information on the procedure on the internet. http://www.ringpinion.com has a nice document describing what you need to do, and the toyota manual also contains all the info you need. (It's only a bit difficult to read if you dont know what their talking about.).
Basically there are 3 adjustments you need to do.. the first one is pinion depth. You adjust this with washers behind the pinion, and check if it's correct by installing the diff and checking the contact pattern. Then there is the pinion bearing preload. This is adjusted by how tight you tighten the pinion nut. You can adjust it by torque-ing the nut to a specified amount and then check how much torque is needed with an inch-pound (or cm-Nm) torquewrench (also known as torque-meter).
The backlash is the amount of play between the pinion and ring gear. This is adjusted with the rings on the side. You need a micrometer to check how much movement there is between the gears.
The side bearings of the diff also need to be set to a certain preload, which is also done using the micrometer...it's all in the manual.
  4AGE overhaul kits/ Brian Crower stroker kit Lt86 1 4,186 06-13-2015 06:53 PM
Last Post: corolla4agze
  rebuild overhaul 4AGZE Gtsi-R 2 4,509 09-29-2012 05:04 PM
  What Diff Oil For a Clutch plate diff? jamieae86 10 14,320 12-16-2011 11:14 AM
Last Post: bakonick
  weight diff head diff center fax0815 5 6,815 12-21-2010 03:03 PM
Last Post: fax0815
  transmission overhaul set peter 18 15,630 01-08-2010 10:52 AM
Last Post: peter
