Diff overhaul
01-14-2006, 02:27 PM
Diff overhaul
I’m planning to do diff overhaul these days, does anybody know oil seal spec?
AE86 rear end bearing kit includes the following: pinion nut [color=red:23edc5a81a]oil seal ???[/color:23edc5a81a] pinion bearing front pinion bearing rear crush sleeve carrier bearing x2 pumpkin gasket Fun is not the straight line! |
01-17-2006, 12:52 PM
Diff overhaul
I’ve just ordered from Toyota:
pinion nut oil seal crush sleeve diff gasket kit The cost is around 30€ for all. I bought bearings separately. Fun is not the straight line! |
01-17-2006, 01:29 PM
Diff overhaul
have you got part number???
![]() Always remember: Rev it till it blows, then back off a bit... Zenkis - Orange, Red/Black, Silver/Black, Maroon/Blue Koukis - Red, Silver/Gray, |
01-17-2006, 02:28 PM
Diff overhaul
dAYTONA Wrote:have you got part number??? Here you are, diff part numbers. Fun is not the straight line! |
01-23-2006, 05:02 AM
Diff overhaul
Thanks.
01-23-2006, 09:46 PM
Diff overhaul
I rebuilt my diff unit a while ago, which was fairly straight forward to do, but what wasnt very easy was setting the backlash and pre-load etc! Took hours and hours to get it right!
01-23-2006, 09:51 PM
Diff overhaul
is this the same set off parts for zenki and kouki diffs?
http://www.86ers.org All the hachies that Daytona can only dream about. |
01-24-2006, 12:16 PM
Diff overhaul
SekiguchiUeno Wrote:is this the same set off parts for zenki and kouki diffs? The safest way is to give them your VIN. You will not make a mistake with part numbers. I did like that. Fun is not the straight line! |
01-30-2006, 12:07 AM
Diff overhaul
2 Black betty: How did you adjust backlash and pre-load?
Got any advice? 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
01-30-2006, 10:03 AM
Diff overhaul
Do a search Kas, there is a lot of information on the procedure on the internet. http://www.ringpinion.com has a nice document describing what you need to do, and the toyota manual also contains all the info you need. (It's only a bit difficult to read if you dont know what their talking about.).
Basically there are 3 adjustments you need to do.. the first one is pinion depth. You adjust this with washers behind the pinion, and check if it's correct by installing the diff and checking the contact pattern. Then there is the pinion bearing preload. This is adjusted by how tight you tighten the pinion nut. You can adjust it by torque-ing the nut to a specified amount and then check how much torque is needed with an inch-pound (or cm-Nm) torquewrench (also known as torque-meter). The backlash is the amount of play between the pinion and ring gear. This is adjusted with the rings on the side. You need a micrometer to check how much movement there is between the gears. The side bearings of the diff also need to be set to a certain preload, which is also done using the micrometer...it's all in the manual. FABRICA MI DIEM, PVNC! |
4AGE overhaul kits/ Brian Crower stroker kit | Lt86 | 1 | 4,190 |
06-13-2015 06:53 PM Last Post: corolla4agze |
rebuild overhaul 4AGZE | Gtsi-R | 2 | 4,514 |
09-29-2012 05:04 PM Last Post: Ivan141 |
What Diff Oil For a Clutch plate diff? | jamieae86 | 10 | 14,345 |
12-16-2011 11:14 AM Last Post: bakonick |
weight diff head diff center | fax0815 | 5 | 6,825 |
12-21-2010 03:03 PM Last Post: fax0815 |
transmission overhaul set | peter | 18 | 15,663 |
01-08-2010 10:52 AM Last Post: peter |
