Digital Dash
02-14-2021, 07:54 AM
Post: #181
Digital Dash
(02-05-2021 05:43 AM)mister86 Wrote:  ...not sure how to get the digital dash to work now (worked previously with the stock ecu).
Are you saying that you had the digital dash including tacho working when it was connected
to the OEM Toyota ECU in a non-factory digital dash car ?
Cheers... jondee86
02-14-2021, 04:20 PM
Post: #182
Digital Dash
Cheers... jondee86
That is correct.
02-14-2021, 09:41 PM
Post: #183
Digital Dash
Did you do the dash conversion, or was it already in the car when you bought it ?
Cheers... jondee86
02-14-2021, 09:46 PM
Post: #184
Digital Dash
(02-14-2021 09:41 PM)jondee86 Wrote:  Did you do the dash conversion, or was it already in the car when you bought it ?
Cheers... jondee86
I did the dash conversion with help from Ronnie on the Club4AG forums. I bought the digital fuel sender, oil pressure sensor and cooling sensor, and then he modified the digital gauge cluster to be plug n play.
02-15-2021, 03:45 AM
Post: #185
Digital Dash
And by "plug-n-play" you mean that you used the same dash harness that was used for
the analog dash and just changed the sensor plugs for the fuel, oil and coolant sensors ?
No change to the igniter ?
Cheers... jondee86
02-15-2021, 03:49 AM
Post: #186
Digital Dash
(02-15-2021 03:45 AM)jondee86 Wrote:  And by "plug-n-play" you mean that you used the same dash harness that was used for
Cheers... jondee86
Correct on the sensors. And yes. Same dash harness with a few changes to how the analog vs digital dash was wired since it’s slightly different.
And got rid of the igniter to use with my aftermarket ECU and coil on plug.
02-15-2021, 05:10 AM
Post: #187
Digital Dash
Do you still have the igniter that worked with the digital dash before you changed
to the LINK and COP's ?
Cheers... jondee86
01-07-2023, 10:32 PM
Post: #188
Digital Dash
Anyone tried this out with a Beams engine?
exact if oil pressure sensor and water temp sensor working digital?
Any one tried this out for the Fuel sender conversion maybe:
https://spiyda.com/fuel-gauge-wizard-mk3.html
01-08-2023, 10:44 PM (This post was last modified: 01-08-2023 10:44 PM by banpei.)
Post: #189
Digital Dash
A few years ago I planned to do a conversion using an arduino:
http://www.aeu86.org/forum/Thread-Digita...#pid174731
I never did this as shortly afterwards the AE86 was put into storage. The Gauge Wizard seems to solve the exact same problem in a similar way, but then more universal. What I like is that it's also able to calibrate. Thumbs up!
[Image: AEU86 AE86 - Digital Dash]
04-10-2024, 03:28 PM (This post was last modified: 04-10-2024 11:00 PM by banpei.)
Post: #190
Digital Dash
Today this arrived:
I've ordered the Spiyda Gauge Wizard. A few weeks ago I already bought a NOS analogue fuel sender for the Carina. It has the exact same resistance on low and high fuel levels as the AE86 analogue sender, so it will be a good test mule for the Spyda. In a few weeks time I'll have some spare time on my hands and try to test if the Gauge Wizard can be used to convert the resistance to voltage.
  Digital speedometer on stock dashboard FanIsHere 0 1,287 11-09-2022 01:36 PM
Last Post: FanIsHere
  Dash Waning Lights pack 7 4,002 10-06-2021 01:00 PM
Last Post: pack
  Trueno Digital dash kph to mph Bojack 3 6,805 11-21-2018 12:27 AM
Last Post: kazi
  Custom Dash Cluster kazi 14 19,581 10-24-2017 09:05 PM
Last Post: kazi
  Dash Lights kazi 3 5,574 09-12-2017 10:04 PM
Last Post: kazi
