Distributor cap heat protection
08-30-2005, 03:31 PM
Yesterday, I find out that my distributor plastic cap has been damaged because of high temperature coming from exhaust. I don’t have any heat protection plates so I’ll have to put something to protect new distributor cap. Any suggestion? thx
Fun is not the straight line!
08-30-2005, 04:14 PM
If you have a stock exhaust you can try finding the upper heat shield for it. You could also try building a distributor heatshield yourself, or you can order one from http://www.aerodyne.net .
08-30-2005, 10:18 PM
made my own...
09-25-2005, 08:45 PM
An aw11 (early MR2) distributor has a built-in heat shield. Run the aw11 dizzy, cap and wire set. Put a new o-ring on before you install it Smile
Or you can make your own...
  Cam Cap Bolt Snapped!! Alex170984 1 3,915 06-08-2018 01:17 PM
  16v distributor hole plug harkes 8 9,888 10-12-2016 11:13 AM
Last Post: harkes
  Changing distributor when carb 4age izanagi 14 16,310 07-04-2016 03:27 PM
Last Post: Uzelac
  Distributor position and cranking pack 13 20,227 07-01-2013 11:08 PM
Last Post: pack
  4AGE Heat Shielding Intake Gasket asyrigos 11 24,507 04-01-2013 10:58 AM
Last Post: asyrigos
