Doc's KE20: - really coming together now
01-20-2010, 11:33 AM
Post: #461
remove the rust from the engine bay?
01-20-2010, 12:05 PM
Post: #462
parrot Wrote:It's odd isn't it. You would assume there would be an area of reinforcement with an undrilled hole to accept a clutch master in shells destined to be TE2x's. TE2X have a completely different firewall strengthening plate. BMC in a different location etc ect. Mayor disappointment. @Doc, will you strengthen the firewall similar to the BMC or brace the clutch master in any way? Can you see the firewall moving when you try and operate the clutch? Nice going for showing the rest of us how to tackle this problem! Time to find an AE82 on the junk and get to work on mine. A wheel to steer the front of the car A pedal to steer the rear |
01-20-2010, 01:21 PM
Post: #463
Mmmm, would he be interested in doing the same on my TA60?
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
01-20-2010, 04:32 PM
Post: #464
parrot Wrote:I bet you were shitting yourself with the drill poised! YES i was! That's why it took a year, i'm not that confident of myself to drill a hole that large in my firewall, so i only did it when i had somebody to help! parrot Wrote:How many times did you check your measurements first? Thanks! We did check it a couple of times (like: measure twice, cut once..) but still got it wrong It's in now, it doesn't deserve an award for nicest job, but it works! NoHachi Wrote:@Doc, will you strengthen the firewall similar to the BMC or brace the clutch master in any way? Can you see the firewall moving when you try and operate the clutch? The firewall is 4 sheets thick in the BMC area and 3 sheets thick in the CMC area. I can't see the firewall moving, because there's no engine and no clutch in the car yet, so the CMC doesn't really have to 'work' yet, there's almost no resistance in the pedal. Btw, almost all Toyota CMC's will work, i know that Robert (i think you know him Damir, he had the brown KE20 with 2T engine) uses a Starlet EP82 master cylinder. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
01-20-2010, 04:46 PM
Post: #465
Thanks doc. Already knew about the CMC thing. Just need an XX82 for its bonnet closing mechanism as well.
01-28-2010, 02:00 PM
Post: #466
i'm waiting like crazzy to see your car running, since my kp61 starlet will have a 2tg and i never drive one or saw one running
Good work Always on top always on sideways http://img512.imageshack.us/img512/6080/...tomrx5.jpg |
01-29-2010, 12:18 PM
Post: #467
What are you looking for off an AE82? There are millions of them here, and I'm off to the wreckers on Sunday morning. Happy to send something if it isn't too big.
Edit. woops, sorry this was meant to be a PM! |
03-20-2010, 02:17 AM
Post: #468
well, as seen in the previous post, the old brake setup didn't fit anymore, so i had to fiddle with that to make it work.
Ingredients: single exit brake thingy: bit of brake pipe: T-piece of a donor rear axle: Should work! Also refitted the rear shocks, and when i had the wheels off, i couldn't resist testing the SSR wheels on the car I put a tire on 1 wheel, to try and do the hairspray trick, but i failed and damaged the wheel in the process, needs to be resprayed now The car is on ride height on these pics: widthwise they are very good fitting! 1mm outside the flares on each side! But there's still a big arch gap, way to big for my liking: I think i'll go for some bigger tires, 195/45 is too small for my liking (should've tought about that when i ordered tires : ) Other then that, they look awesome to me! also refitted rear lights: "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
03-21-2010, 05:14 PM
Post: #469
That archgap should disappear mostly when it sits on its feet.
But then you still have a gap on the sides. I'd say: fit some stretched ballons on it and you won't notice it that much anymore. 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
03-22-2010, 03:57 PM
Post: #470
the jack = underneath the rear axle here, so it sits at ride heigt
Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 86,779 |
06-22-2015 02:56 PM Last Post: Uzelac |
My little (not really...) project - Soon to be all done?!? | Jan Pedersen | 516 | 575,388 |
AE86 from Portugal (restoring gearbox now...) | Homem Bomba | 13 | 22,496 |
01-01-2013 11:45 PM Last Post: Homem Bomba |
Levin Coupe from Croatia - NOW SR86 with IRS | ZaX | 698 | 702,517 |
10-01-2012 08:07 PM Last Post: ZaX |
Ricks project AE85 (Back together with dyno results) | Rick | 132 | 222,927 |
07-05-2011 11:54 AM Last Post: Rick |
User(s) browsing this thread: 13 Guest(s)
