Does a throttle bodie setup still need an afm?
08-27-2006, 08:28 PM
I understand your arguments Ben, but aren't you affraid of the effects of unforseen VE changes? Clogged cats/airfilters etc etc? Thats the reason I would like to run of off a map system for a daily driver..For a racecar - tps no contest.
There should be a way of working round any (more or less) constant VE changes with a TPS system..You should be able to compare and adjust VE tables by monitoring constant idle fueling and RPM. That would allow you to adjust the main MAP to the new VE allowing safe TPS mode..Time to learn C and buy a MS system. It worked nicely in GT power.
Messages In This Thread
[] - NoHachi - 08-26-2006, 01:19 AM
[] - BenR - 08-26-2006, 11:34 AM
[] - NoHachi - 08-26-2006, 02:06 PM
[] - BenR - 08-27-2006, 02:40 AM
[] - NoHachi - 08-27-2006 08:28 PM
[] - BenR - 08-27-2006, 10:36 PM
[] - NoHachi - 08-27-2006, 11:18 PM
[] - BenR - 08-27-2006, 11:41 PM
[] - Mux213 - 08-28-2006, 12:34 AM
[] - BenR - 08-28-2006, 01:14 AM
[] - Mux213 - 08-28-2006, 09:39 AM
[] - krijn - 08-29-2006, 12:01 AM
[] - BenR - 08-29-2006, 12:45 AM
[] - krijn - 08-29-2006, 12:56 AM
[] - Mux213 - 08-29-2006, 01:02 AM
[] - BenR - 08-29-2006, 03:51 AM
[] - NoHachi - 08-29-2006, 10:52 AM
[] - BenR - 08-29-2006, 12:58 PM
[] - krijn - 08-30-2006, 10:59 PM
  AFM to Map Conversion ps13michi 3 3,438 01-06-2022 10:34 AM
Last Post: ps13michi
  Anyone know what this plug does? Super86 3 6,384 08-01-2016 03:57 PM
Last Post: Nakilad
  Bluetop AFM with air filter izanagi 4 7,200 04-29-2016 07:29 PM
  4 Link setup and Traction brackets Jezza_hr 5 10,449 07-21-2014 09:12 PM
  smallport question AFM or MAP? fax0815 5 8,486 05-17-2014 05:07 AM
Last Post: jondee86
