Does anyone know of a system to have the following readings?
07-29-2010, 08:39 AM
there's another stack/DSSC like thing around but I can't find it anymore... from memory it was substanialy below US$1000...
AE86 ex-daily |
07-29-2010, 09:56 AM
anyone knows which brand/type Bean Bandit is talking about???
Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-29-2010, 11:54 AM
Quote:anyone knows which brand/type Bean Bandit is talking about??? Not sure if this is it, but I run this in my Nissan Silvia - it does all that you're wanting it to do, maybe with the exception of fuel pressure. http://www.aimsports.com/products/mxl-chooser.html I run it with a standalone ECU and the best part about it is that it just plugs into the CAN port on the computer, minimizing wiring. The only thing that needed separate configuring was the fuel gauge everything else is direct from the ECU. http://www.super86.co.nz |
07-30-2010, 01:21 AM
Hey thanks Super86.. how much are these???
07-30-2010, 08:25 AM
PLX devices. Using a single 2 1/16" gauge you can cover a whole range of different inputs.
http://www.plxdevices.com/multigauges.html Any digital dash. There are a lot available from the bike/quad/motorsports world that might be able to be adapted. Andrew |
07-30-2010, 12:43 PM
Quote:Hey thanks Super86.. how much are these??? The cheapest model (and the one I am currently running) retails for $1129USD You will also spend a bit on installation unless you do it yourself - but totally worth it for the fact it is all your gauges in one! It also has programmable warning alarms and staged shift lights built in. Man, I should be selling these things for them! http://www.super86.co.nz |
07-30-2010, 01:40 PM
PLX Multi Gauges need OBDII or many sensors + Sensor Modules...
Take a look on Zeitronix Zt-2, seem to be good for what you want to do |
07-31-2010, 10:34 PM
Hey Project D actually even this comes around 1000 USD for the 3 items I want..
Seems like cheap gauges the way for me Cheated on my いたずらな女の子 and now I can't get enough of her.. |
Exhaust has white smoke coming out and I dont know why... | mister86 | 3 | 4,471 |
01-19-2020 12:06 AM Last Post: Power_uP |
Stack display system, need help | Jimmi The Kid | 1 | 4,199 |
01-15-2017 10:52 PM Last Post: Ivan141 |
Anyone know what this plug does? | Super86 | 3 | 6,138 |
08-01-2016 03:57 PM Last Post: Nakilad |
How would/have you rebuild your 4age? | joaotcgt | 6 | 8,845 |
07-21-2015 10:40 AM Last Post: mad.matt |
How far should I have to push my clutch in | dinkers542 | 4 | 6,066 |
11-29-2014 11:18 PM Last Post: dinkers542 |
