Door Open Notifer ring thing
07-29-2005, 08:30 PM
I want to rip out that annoying sound out of my car. I could either...
Change the sound. somehow or. rip out the ringer or whatever. Sniper ----------------------------- 1986 Toyota Corolla SR5 1989 BMW 535i 1986 Volvo 740 GLE ----------------------------- |
07-29-2005, 08:49 PM
If you can find it you would be able to take out the ringer.
BTW is the ringer stock in your car? Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
07-29-2005, 09:40 PM
I've got mine still connected to the old wireloom, so it's outside my vehicle and TE71Corolla didn't put it back. (thank god!)
I'd recomend to remove it entirely. I think it's situated underneath the driverseat if I look at the drawings of the wires. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
07-29-2005, 11:42 PM
Can I change the sound? or just rip the whole thing out?
07-30-2005, 03:23 AM
Ah, well in my car, the sound seems to be coming from the glove compartment. It dark out so I didnt do any snooping around. BUt i guess my best option is to rip that crap out. lol
07-30-2005, 07:41 AM
I just tore part of a tissue off and made a small thick square, and put it in between what makes the vibration (sound) in the glove compartment. Open the glove compartment, and inside to the right toward the top (close to you) there will be a tiny black box, pull that out, and i believe you have to pull it to your left, then unhook the wires from it. get a flathead screwdriver and open the box up (3 or 4 little hooks at the bottom). and stick the tissue where the vibrtions are created. If you cant find it you can always hook it back up with the top cap thing off, open a door, and watch for it, and listen for it(this is just what i did). you should know where to stick the tissure or napkin to stop it from vibrating.
07-30-2005, 01:44 PM
Down5Zigen Wrote:I just tore part of a tissue off and made a small thick square, and put it in between what makes the vibration (sound) in the glove compartment. Open the glove compartment, and inside to the right toward the top (close to you) there will be a tiny black box, pull that out, and i believe you have to pull it to your left, then unhook the wires from it. get a flathead screwdriver and open the box up (3 or 4 little hooks at the bottom). and stick the tissue where the vibrtions are created. If you cant find it you can always hook it back up with the top cap thing off, open a door, and watch for it, and listen for it(this is just what i did). you should know where to stick the tissure or napkin to stop it from vibrating.I do have the blackbox indeed: it has written "buzzer" on it, so I guess its exactly the same thing. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
07-31-2005, 12:02 AM
HAHAHAHAHAHAH (Evil Laugher)
I got that little b***h!!! i wrote down what it says, just incase someone cares what it says. ah, finally peace in my car.... Sniper ----------------------------- 1986 Toyota Corolla SR5 1989 BMW 535i 1986 Volvo 740 GLE ----------------------------- |
07-31-2005, 12:49 PM
That wasnt so hard now was it Good job!
ring gear bolts | DJexor | 3 | 5,329 |
12-26-2016 10:56 PM Last Post: totta Crolla |
Checking ring gear diff | izanagi | 3 | 4,937 |
07-09-2014 07:38 AM Last Post: jondee86 |
Ring & pinion ratio. | izanagi | 27 | 26,825 |
07-05-2014 07:35 PM Last Post: assassin10000 |
do you confirm the hub ring for our AE86 is 73.1-60.1 mm? | makkuro | 4 | 5,199 |
05-31-2011 06:35 PM Last Post: Jan Pedersen |
ring and pinion | totta Crolla | 8 | 6,924 |
11-10-2008 07:24 PM Last Post: totta Crolla |
