Door length
03-18-2014, 10:05 AM
Door length
Can anybody tell me how long an ae86 door is (preferably in cm's)?
If anyone can take a tape measure and check the length at the bottom and perhaps 20 cm's higher I would be most grateful.
I need to buy some sheetmetal do create some lower door skins for my project, and would like to avoid having to create a skin out of multiple pieces
I can't transport 2 by 1 meter sheets of metal in my little daily driver, so I usually have them cut in half, but I expect the door is longer than 1 meter so I need to know. Think I might also have them bend a lip on two panels for me since my bending brake is only 80cm's wide.
03-18-2014, 11:18 AM
Door length
Hi Ivan,
just measured for you.
The bottom: (has curves at either end) between 1257mm and 1265mm
200mm up: 1325mm
Widest part I could find (along the indented trim line) measured at 1337mm
If you need anymore just ask.
hth
03-18-2014, 02:11 PM
Door length
That's all the info I need.. thanks a lot totta!
  Rear arm length totta Crolla 7 1,526 06-05-2024 08:53 AM
Last Post: totta Crolla
  4AGE 20v Ignition Lead Length mad.matt 3 6,944 10-01-2014 03:43 PM
  ae86 crush sleeve length choyr 15 21,566 02-26-2014 05:03 PM
Last Post: choyr
  Length of factory cat Rick 4 7,940 08-07-2013 06:03 AM
Last Post: jondee86
  Valve springs length Vil 4 6,077 04-04-2013 07:41 PM
