Driveshaft diffraction angle/ need help
01-21-2010, 03:35 PM
Do anyone know if the driveshaft has a constructive diffraction angle? Or ist the gearbox input shaft on the same lever as the differential axle.
The point is I have swapped the engine to an F20C and at the moment this angle is about 3,5°. I have doubts that any driveshaft withstand the load!!
01-21-2010, 04:01 PM
normally it should be around 3°, don't know for sure what it is on AE86s though
01-24-2010, 07:51 AM
CSM Wrote:Do anyone know if the driveshaft has a constructive diffraction angle? Or ist the gearbox input shaft on the same lever as the differential axle.
You didn't take into account the downward slope of the driveshaft to the rear end, due to the chassis design & suspension setup typical of these cars when lowered.
Typical AE86 motor sit's at 3.5-4 deg nose up. Driveshaft (1-piece) is around 2.5 degrees. So if you match the 3.5-4 deg nose up at the diff you have working angles of around 1-1.5 deg for the u-joints. Which is well within the safe margins.
Andrew
  Need help installing replica "OEM" sideskirts sheppardpat47 3 1,306 08-09-2026 12:46 AM
Last Post: sheppardpat47
  Windshield. Need Help. Roma_trueno 13 26,226 02-02-2026 02:19 PM
Last Post: totta Crolla
  Need help identifying this! takumi_mt 4 3,582 04-05-2024 09:17 AM
Last Post: takumi_mt
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 14,256 07-28-2022 10:48 PM
  TRD ECU need help ps13michi 5 7,480 02-18-2022 10:42 AM
Last Post: ps13michi
