TRD ECU need help
01-10-2022, 03:59 PM (This post was last modified: 01-10-2022 09:22 PM by ps13michi.)
TRD ECU need help
Hello again,
i need some assistance. I got my hands on a trd ECU for my 4age. Came of a ae92 but my problem is where to find the inner switches to set it for ae86.
I found the plan here in the forum so verry nice Hurray!
ECU Number is 83660 - SP051
I will post pics this evening
Engine specs
Toda cams 272 in 264 out
Toda cam gears
ARC Airbox
martelius Header - Hemi Exhaust 2,5"
TRD Sparc plug wires
Maby I ll give it a go and try it - Water, Oil Temp, pressure and Wideband are installed to check the stats of my engine.
01-11-2022, 09:41 AM
TRD ECU need help
Yesterday evening i found the switches to set for ae86 they are under the metal.
So there are many options group a or n1 specs due to my specs its more group a i guess.
01-11-2022, 11:28 AM
TRD ECU need help
Nice find and good to know for future reference. Thumbs up!
I looked into my TRD bible, but there was no documentation on the ECU, just the part numbers. I guess you used to get a proper manual with it when it was new.
[Image: AEU86 AE86 - TRD ECU need help]
01-13-2022, 08:43 PM
TRD ECU need help
Yes I found the manual here in an older post super cool.
I will also try to get it running on Saturday.
The Switches are set for 4age and ae86 group a which is the nearest to my mods. n1 would be to hard for my car.
02-14-2022, 04:53 PM
TRD ECU need help
makes it easier............. feel free to share!
Dan -
02-18-2022, 10:42 AM
TRD ECU need help
(02-14-2022 04:53 PM)oldeskewltoy Wrote:  makes it easier............. feel free to share!
Yes perfect. I do my injectors new and than Ill try it again. Maby with car model AE86 and spec blank the last time I tried it with spec group a but car run like shit...
I´ll give it a last try otherwise I will sell it or it gets a place in the living room
  Need help identifying this! takumi_mt 4 1,291 04-05-2024 09:17 AM
Last Post: takumi_mt
  Need some help DJexor 4 5,621 03-13-2018 05:37 PM
Last Post: pack
  TRD multi-ECU manual Two Sheds 10 20,566 07-12-2017 12:21 AM
Last Post: jondee86
  JDM trueno not starting. need help! kazi 8 9,268 03-12-2017 05:05 PM
Last Post: kazi
  Stack display system, need help Jimmi The Kid 1 4,497 01-15-2017 10:52 PM
