TRD ECU need help
01-10-2022, 03:59 PM
(This post was last modified: 01-10-2022 09:22 PM by ps13michi.)
TRD ECU need help
Hello again,
i need some assistance. I got my hands on a trd ECU for my 4age. Came of a ae92 but my problem is where to find the inner switches to set it for ae86. I found the plan here in the forum so verry nice ![]() ECU Number is 83660 - SP051 I will post pics this evening Engine specs Toda cams 272 in 264 out Toda cam gears ARC Airbox martelius Header - Hemi Exhaust 2,5" TRD Sparc plug wires Maby I ll give it a go and try it - Water, Oil Temp, pressure and Wideband are installed to check the stats of my engine. |
01-11-2022, 09:41 AM
TRD ECU need help
Yesterday evening i found the switches to set for ae86 they are under the metal.
So there are many options group a or n1 specs due to my specs its more group a i guess. |
01-11-2022, 11:28 AM
TRD ECU need help
Nice find and good to know for future reference.
I looked into my TRD bible, but there was no documentation on the ECU, just the part numbers. I guess you used to get a proper manual with it when it was new. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
01-13-2022, 08:43 PM
TRD ECU need help
Yes I found the manual here in an older post super cool.
I will also try to get it running on Saturday. The Switches are set for 4age and ae86 group a which is the nearest to my mods. n1 would be to hard for my car. |
02-14-2022, 04:53 PM
TRD ECU need help
makes it easier............. feel free to share!
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-18-2022, 10:42 AM
TRD ECU need help
(02-14-2022 04:53 PM)oldeskewltoy Wrote: makes it easier............. feel free to share! Yes perfect. I do my injectors new and than Ill try it again. Maby with car model AE86 and spec blank the last time I tried it with spec group a but car run like shit... I´ll give it a last try otherwise I will sell it or it gets a place in the living room |
| Need help identifying this! | takumi_mt | 4 | 2,278 |
| Need some help | DJexor | 4 | 6,726 |
03-13-2018 05:37 PM Last Post: pack |
| TRD multi-ECU manual | Two Sheds | 10 | 23,922 |
07-12-2017 12:21 AM Last Post: jondee86 |
| JDM trueno not starting. need help! | kazi | 8 | 10,885 |
| Stack display system, need help | Jimmi The Kid | 1 | 5,301 |
01-15-2017 10:52 PM Last Post: Ivan141 |
![AEU86 AE86 - TRD ECU need help [Image: AEU86 AE86 - TRD ECU need help]](https://www.aeu86.org/sticker-banner-468.gif)
