Driveshaft free play
02-23-2015, 01:48 PM
Hi all. I recently noticed that the drive shaft in my ae86 has a lot of free play around. 1/4 is it normal?
Since we had two other 86's on the garage we checked the other two and the free play was much less in the other cars. So i wonder, is the free play an indication of worn crown pinion and drive shaft or not? The rear axle has a 2way trd lsd I hear no strange noises whatsoever, and the car is lowered around 5 cm (i don't know if that affects the angle of the drive shaft) and an adjustable panhard rod is already fitted. Any suggestions welcomed ![]() ALWAYS SIDEWAYS!!!!! |
02-23-2015, 03:25 PM
Seen this with a broken LSD once, it's less likely if you have a a trd diff though.
02-23-2015, 11:12 PM
(This post was last modified: 02-23-2015 11:14 PM by zenki.)
I had the same problem back in '13 with a stock worn zenki diff. Drivetrain would vibrate sometimes, making accelerating and decelerating kinda funny. And the driveshaft had even more play than 1/4 on mine. I just put another diff and crown pinion in and it was gone.
ハチロク ![]() |
02-24-2015, 12:37 AM
1/4 of a turn seems much... I´ve had some play, that resulted from worn spline on my driveshafts. Have you got the right shafts for your diff? I remeber zenki shafts fit a kouki diff, not for long and with play!
02-24-2015, 11:23 AM
Thanks for the replies, the axle is the oem (zenki) with 350000 km except the diff which has been changed with a trd 2way(zenki). I noticed the free play while i was changing the gear oil and the car was lifted. The funny thing though is that the car even at high speeds on the freeway -in terms of drive shaft-diff noise- is almost silent.
But i guess sooner or later i 'll have to open the axle and see what is going on inside..... ALWAYS SIDEWAYS!!!!! |
02-24-2015, 09:14 PM
(02-23-2015 01:48 PM)thanos Wrote: ...is the free play an indication of worn crown pinion and drive shaft or not? No. It'd never be the ring gear/crown wheel and pinion gear mesh having that much clearance without very noticeable & disastrous results. The play is in the small spider/pinion gears and/or the pinion gear's splines for the axle. Usually harmless. Driveshaft/propeller shaft U-Joints? So what! |
02-25-2015, 02:10 AM
(This post was last modified: 02-25-2015 02:11 AM by thanos.)
I spoke with the mechanic this evening and he also mentioned that since the driveshaft-diff are quiet, a ring/pinion failure seems unlikely, however we will have to open the axle soon just to make sure.
(02-24-2015 09:14 PM)allencr Wrote: Driveshaft/propeller shaft U-Joints?We checked the U joints and they were in very good condition also I forgot to mention that the center bearing was like new (replaced in 2007 and has less than 35000 km from then) ALWAYS SIDEWAYS!!!!! |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 8,270 |
07-28-2022 10:48 PM Last Post: banpei |
Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 2,493 |
05-10-2021 01:02 PM Last Post: Project D |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 7,253 |
Driveshaft question | DidiDex | 3 | 5,692 |
02-12-2015 09:43 AM Last Post: DidiDex |
anyone produce new harness for bluetop?gts driveshaft | dinkers542 | 8 | 8,699 |
11-25-2014 09:18 PM Last Post: dinkers542 |
