Kaaz 1.5 way Diff - Driveshaft Compatability
05-09-2021, 07:57 PM
Hi all, my kouki jap spec 86 has a standard diff with no lsd. I've decided to go with a Kazz 1.5 way diff. Do I need to measure the shaft first prior to ordering?
I'm aware the zenki drive is different but is there anything else I need to check compatability wise? |
05-10-2021, 01:02 PM
The axle shaft are the only things you need to check. Everything else is the same as long as it's an AE86 rear end (6.7" ring and pinion).
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 8,359 |
07-28-2022 10:48 PM Last Post: banpei |
Help needed: is it 1 way or 1.5way LSD | Dino86 | 2 | 3,851 |
05-17-2019 09:08 AM Last Post: Ivan141 |
Tomei 16V poncams + Tomei technical trax 1.5 way LSD | Lt86 | 22 | 20,973 |
09-16-2016 09:56 PM Last Post: Alex170984 |
Driveshaft free play | thanos | 6 | 9,970 |
02-25-2015 02:10 AM Last Post: thanos |
Driveshaft question | DidiDex | 3 | 5,709 |
02-12-2015 09:43 AM Last Post: DidiDex |
