Dual circuit brakes
11-07-2005, 11:46 AM
Dual circuit brakes
Can anyone tell me how the dual circuit brakes are 'split' is it front/rear or diagonal ?
I want to fit a bias valve and need to know this thanks. Also does the car have a factory set bias valve ? An analogue brain in a digital World |
11-07-2005, 11:56 AM
Dual circuit brakes
It's split front/rear...I dunno about the factory bias, but there is a splitter under the master cilinder (mounted against the strut tower) that might have some biasing functionality..but I'm not sure about that.
11-07-2005, 12:08 PM
Dual circuit brakes
This splitter has integrated bias valve. You must remove it, make your own "T" splitter (2 lines for each front caliper and one line to rear end) and put your bias valve to the line to rear end. Avoid using 2 bias valves in one circuit !!!
11-07-2005, 12:18 PM
Dual circuit brakes
Fantastic response, I can get on with it today now.... Thanks guys !! An analogue brain in a digital World |
Rear brakes | totta Crolla | 0 | 949 |
02-03-2023 12:54 PM Last Post: totta Crolla |
Switching diffs for disc brakes? | trippin | 6 | 2,754 |
07-08-2022 03:35 AM Last Post: trippin |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,812 |
Hydraulic handbrake with stock rear brakes | Dino86 | 11 | 15,609 |
07-11-2014 08:33 PM Last Post: Dino86 |
S13 Front brakes in AE86 rear | heshan | 25 | 28,399 |
02-01-2014 12:37 PM Last Post: heshan |
