ECU problem ?
03-14-2010, 03:20 PM
ECU problem ?
I think what is happening to my engine is a bit odd and I wondered if someone could shed some light on it.
New Bigport 16v engine install, complete TVIS system removed including butterflys etc.
Engine starts ok and runs with the engine management light showing, after maybe 20 seconds the engine management light goes out and the engine stops Huh
I have read the error codes and it comes back as 2, pressure sensor. I assume this is because the TVIS plug is disconnected ?
03-14-2010, 04:50 PM
ECU problem ?
Sorted Thumbs up!
MAP sensor connector not pushed ALL the way in... Blush Blush
  4agZe problem solved - 99% IC problem Okami 41 35,603 07-12-2012 04:49 PM
Last Post: Okami
  AC problem? Idle problem? KD2229 3 4,727 08-19-2009 02:08 AM
Last Post: KD2229
