Early tvis red top from e9 gti small or bigport?
04-19-2018, 10:29 PM
Hello,
Its been a while i was here i have a question as says subject i have from my dismantled e9 gti red top 4age engine i have trouble to understand if it is bigport or smallport if it got tvis the block is 7rib. Some local guy want head and intake if it is small port. Another option i have to use it for my spare engine which is 7rib block with blue top head but i am not sure if it can be fitted. The block on the e9 was having damaged piston bearings i am not sure if it is worth rebuilding it i will be as well not able to use the intake as it is reversed i think. In future i plan to swap the spare engine to my coupe as the old engine is getting tired as i feel it. The spare was running really strong as i remember in my first coupe but was taken out as the chassis was over rusted and not worth saving. Any ideas what will be the best for me? Thank you.
85' AE86 GT coupe lifetime project since 2005
04-20-2018, 12:04 AM (This post was last modified: 04-20-2018 06:52 AM by jondee86.)
When looking at the intake ports, the bigport has the ports arranged
in two pairs with more space between 2 and 3 than between 1 and 2
or 3 and 4. The smallport has four equally spaced ports, and it also has
an external oil drain at the rear of the head on the intake side. The
bigport does not have this drain.
Cheers... jondee86
04-20-2018, 08:57 AM
Top head ist smallport bottom is bigport Wink
[Image: AEU86 AE86 - Early tvis red top from e9 ...r bigport?]
Daily Beater: Civic EG5
Work in progress Car: AE86
04-20-2018, 09:14 AM
If the engine has a TVIS intake, it's a bigport. In AE92's this would have black and red lettering (black "twincam", red "16 valve").
Smallport has no TVIS, and a different spark plug cover, has all red lettering on one cam cover (red "twincam 16 valve")
  Red top in the ae86 gh0st 25 10,098 08-08-2022 08:43 PM
Last Post: gh0st
  Replacing Top Windscreen Moulding chrisae86 2 1,959 06-18-2022 08:56 PM
Last Post: chrisae86
  Silver top low idle AlexFourTwenty 7 10,093 10-16-2017 10:22 PM
Last Post: AlexFourTwenty
  10.8:1, 264/256° Bigport nyberrg 4 6,267 06-12-2017 09:57 AM
Last Post: nyberrg
  Small Port Swap Alex170984 1 4,135 11-21-2016 01:46 PM
Last Post: Alex170984
