Eibach camber bolts
11-15-2010, 07:48 PM
Eibach camber bolts
I have bespoke top mounts using Bilstein inserts and I cannot use camber
adjustable top mounts. I would like to increase the front camber a little, max 1.5 degrees and I wondered if anyone had used LCA camber bolts or if they were worth a try ? An analogue brain in a digital World |
11-15-2010, 09:31 PM
Eibach camber bolts
There is no bolt adjustment possible on an AE86 unless you cut and shut the LCA and put in a length adjustable rod end.
Only bolt on option besides camber plates is fitting NCRCA's. I have a pair here that I'm willing to part with if you're interested. FABRICA MI DIEM, PVNC! |
11-15-2010, 09:45 PM
Eibach camber bolts
That or adjustable LCA's like nagisa's or T3's
11-17-2010, 02:55 AM
Eibach camber bolts
You could also try different control arms. There may be a longer 'bolt-in' option out there.
http://www.toymods.org.au/forums/showthread.php?t=13452 IF you can find an T130 corona chassis the arms appear to be 10mm longer (which is about -1 deg camber on AE86). Or you can extend your stock control arms, either with heim joints or cut/weld. As with all other modifications, this is a dangerous thing to do so have an excellent welder do it. Andrew |
Head bolts: You decide..... | oldeskewltoy | 8 | 10,425 |
11-11-2020 06:33 PM Last Post: oldeskewltoy |
ring gear bolts | DJexor | 3 | 5,592 |
12-26-2016 10:56 PM Last Post: totta Crolla |
What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 15,451 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
torque setting head cylinder bolts | izanagi | 1 | 5,043 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
Camber adjustment vs original struts | Lt86 | 9 | 9,722 |
05-07-2015 09:45 PM Last Post: zenki |
