Electric Power Steering - What options are available
12-11-2011, 08:45 PM
Hi,
I bought a Quaife quick steering rack and pinion. I think that after fitting it, the steering will get very heavy to handle, especially during parking and low speed manouevres. My idea is to install a electric power steering (electric column). Anyone knows what electric steering columns are available? I read somewhere that the Corsa C units are easy to install. Anyone ever tried it? Thank you. Regards, Pedro Keeping the AE86 alive! |
12-11-2011, 09:59 PM
Well, after some googling i found the Yaris P9 steering column can be fitted into the AE86
However it has to be a non-ABS version which i think never existed in Europe. The steering column part number is 45200-52300. The EPS ECU it's also needed, i think the P/N is 89650-52070. More info: http://hachiroku.net/forums/showthread.php?t=22843 Keeping the AE86 alive! |
12-11-2011, 10:04 PM
Here is Saxspeed´s pics of electric P/S in AE86
http://saxspeed.kuvat.fi/kuvat/SAXSPEED+...G_3213.JPG http://saxspeed.kuvat.fi/kuvat/SAXSPEED+...G_3258.JPG http://saxspeed.kuvat.fi/kuvat/SAXSPEED+...G_3286.JPG http://www.saxspeed.fi here is electric P/S for Escort MK1/2 http://www.mammuttimotorsport.com/images.../Web_1.jpg http://www.mammuttimotorsport.com/images.../Web_2.jpg http://www.mammuttimotorsport.com/images.../Web_3.jpg http://www.mammuttimotorsport.com/images.../Web_4.jpg "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
12-11-2011, 10:08 PM
Saku,
Is that a Corsa EPS applied into the AE86? Keeping the AE86 alive! |
12-11-2011, 10:10 PM
I don´t know, sorry.
EDIT: I e-mailed to Ari, I´ll let you know when he reply. "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
12-12-2011, 06:15 AM
If your gonna be running slalom/drifting the electric PS motor can/will overheat quickly and stop assisting suddenly. At least IIRC from a guy who did it.
The one in the hr.net link you showed I think. Andrew |
12-12-2011, 11:49 AM
It´s from Opel Corsa.
AE86 shaft from motor to steering wheel. It needs positive cable, negative cable and rpm, works when engine is running. "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
12-12-2011, 02:06 PM
I don't use the car in drifting/slalom, only fast road and trackdays...
The main problem is to find a non-ABS Yaris in Europe... ![]() Keeping the AE86 alive! |
12-16-2011, 11:17 AM
i have the Quaife quick steering rack and pinion.
is litle bit more heavy from the oem . is ok i dont think you need power steering i dont . 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
12-16-2011, 12:59 PM
I'm very attentive to this post because i was thinking to buy this "Quaife quick steering rack and pinion", i knew steering will be harder, i use 195/50 R15 tyres, camber: -2º . I use the car for weekend road and fast road
bakonick, what size are your front tyres? Rasteirinho If I remember correctly you have the same tyres size like mine, is the steering too harder or have you the power steering for a comfortable ride? On the other hand, did you ask in toyota (europe) for those parts from non ABS yaris P9? (in Toyodiy 1.100$ for the steering column and 557$ for ECU ![]() http://www.toyodiy.com/parts/p_U_200508_...l?hl=45200 http://www.toyodiy.com/parts/p_U_200508_...l?hl=89650 ...a bit expensive Thanks ![]() ![]() |
Power Steering Removal | 20valver | 2 | 934 |
05-19-2024 06:48 PM Last Post: 20valver |
Power steering clunk | Jezza_hr | 12 | 15,323 |
09-24-2021 01:42 PM Last Post: pack |
ITB filter options | mister86 | 1 | 3,544 |
12-06-2020 10:44 AM Last Post: Bean |
AE86 starter options | max_ae86 | 12 | 30,888 |
07-28-2019 08:17 PM Last Post: harkes |
AE86 rear suspension options 2018 | Alex | 9 | 11,213 |
01-24-2018 02:25 PM Last Post: mad.matt |
