Electric Power Steering - What options are available
12-11-2011, 08:45 PM
Hi,
I bought a Quaife quick steering rack and pinion.
I think that after fitting it, the steering will get very heavy to handle, especially during parking and low speed manouevres.
My idea is to install a electric power steering (electric column).
Anyone knows what electric steering columns are available?
I read somewhere that the Corsa C units are easy to install. Anyone ever tried it?
Thank you.
Regards,
Pedro
Keeping the AE86 alive!
12-11-2011, 09:59 PM
Well, after some googling i found the Yaris P9 steering column can be fitted into the AE86
However it has to be a non-ABS version which i think never existed in Europe.
The steering column part number is 45200-52300.
The EPS ECU it's also needed, i think the P/N is 89650-52070.
More info:
http://hachiroku.net/forums/showthread.php?t=22843
12-11-2011, 10:04 PM
Here is Saxspeed´s pics of electric P/S in AE86
http://saxspeed.kuvat.fi/kuvat/SAXSPEED+...G_3213.JPG
http://saxspeed.kuvat.fi/kuvat/SAXSPEED+...G_3258.JPG
http://saxspeed.kuvat.fi/kuvat/SAXSPEED+...G_3286.JPG
http://www.saxspeed.fi
here is electric P/S for Escort MK1/2
http://www.mammuttimotorsport.com/images.../Web_1.jpg
http://www.mammuttimotorsport.com/images.../Web_2.jpg
http://www.mammuttimotorsport.com/images.../Web_3.jpg
http://www.mammuttimotorsport.com/images.../Web_4.jpg
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
12-11-2011, 10:08 PM
Saku,
Is that a Corsa EPS applied into the AE86?
12-11-2011, 10:10 PM
I don´t know, sorry.
EDIT: I e-mailed to Ari, I´ll let you know when he reply.
12-12-2011, 06:15 AM
If your gonna be running slalom/drifting the electric PS motor can/will overheat quickly and stop assisting suddenly. At least IIRC from a guy who did it.
The one in the hr.net link you showed I think.
Andrew
12-12-2011, 11:49 AM
It´s from Opel Corsa.
AE86 shaft from motor to steering wheel.
It needs positive cable, negative cable and rpm, works when engine is running.
12-12-2011, 02:06 PM
I don't use the car in drifting/slalom, only fast road and trackdays...
The main problem is to find a non-ABS Yaris in Europe... Undecided
12-16-2011, 11:17 AM
i have the Quaife quick steering rack and pinion.
is litle bit more heavy from the oem .
is ok i dont think you need power steering
i dont .
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
12-16-2011, 12:59 PM
I'm very attentive to this post because i was thinking to buy this "Quaife quick steering rack and pinion", i knew steering will be harder, i use 195/50 R15 tyres, camber: -2º . I use the car for weekend road and fast road
bakonick, what size are your front tyres?
Rasteirinho If I remember correctly you have the same tyres size like mine, is the steering too harder or have you the power steering for a comfortable ride?
On the other hand, did you ask in toyota (europe) for those parts from non ABS yaris P9? (in Toyodiy 1.100$ for the steering column and 557$ for ECU Huh )
http://www.toyodiy.com/parts/p_U_200508_...l?hl=45200
http://www.toyodiy.com/parts/p_U_200508_...l?hl=89650
...a bit expensive
Thanks
[Image: AEU86 AE86 - Electric Power Steering - W... available]
  Electric windows totta Crolla 0 638 03-18-2025 11:00 PM
Last Post: totta Crolla
  Power Steering Removal 20valver 2 1,411 05-19-2024 06:48 PM
Last Post: 20valver
  Power steering clunk Jezza_hr 12 16,534 09-24-2021 01:42 PM
Last Post: pack
Thumbs Up ITB filter options mister86 1 3,956 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 32,765 07-28-2019 08:17 PM
Last Post: harkes
