Emissions test failed due to high CO2 levels in IDLE
09-03-2012, 07:26 PM
Hi guys,
I just did my emissions test and it failed!! Sad
They said that the idle CO2 rates are above the limit.
I was told to clean/replace my air filter and also clean my injectors. Next time I was to run this test WITHOUT my air filter and see if that's the problem ..
But do you guys have any pointers? I did this test after I drove around 40km in the city and I was thrashing it a bit..
I noticed my idle was hovering around 1100rpms and I think thats high.. My car is a 4AGZE from an AW11.. I'm wondering whether I should check my MAF and see if there's any servicing needed there.
Also to reduce the idle RPM would the screw on the MAF module help?
Help? Sad
Thanks,
Heshan.
Cheated on my いたずらな女の子 and now I can't get enough of her..
09-04-2012, 08:00 PM
1100rpm is quite high for a normal 4AGE (don't know about the GZE but I reckon it is similar) so either your idle is too rich/high or the cold start injector is working all the time.
[Image: AEU86 AE86 - Emissions test failed due t...ls in IDLE]
  Blacktop 20V high idle Bravothreezero 3 670 08-28-2026 01:11 PM
Last Post: jdm86gtz
  High-beam warning lamp Mylesmck 4 4,572 07-21-2023 07:44 AM
  No idle below 2000 rpm rich running Steller Engineering 3 4,137 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine stress at high speeds gh0st 6 6,101 08-30-2022 07:11 PM
Last Post: Power_uP
  Engine starts/revs but no idle GenkiMotors 17 14,637 11-20-2021 04:12 AM
Last Post: GenkiMotors
