Engine block assembly
05-17-2011, 03:21 PM
Quick request of opinions:
Would you use gasket sealer on the rear crankshaft cover and the oil pump assembly flanges (along with the OEM gaskets of course)? Cheers! SFD |
05-17-2011, 03:25 PM
Depends if the surface is nice or not.
http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
05-17-2011, 03:27 PM
Well, I have sanded the surfaces with fine grit paper, so they are pretty smooth...
SFD |
05-17-2011, 05:49 PM
Scrape off the old gasket, get it sanded with 400, worked fine for me
![]() Are you using paper or metal gaskets? I never really trusted the metal ones if the surface wasn´t mint! 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
05-17-2011, 06:15 PM
Contact areas are prepared for assembly. I will be using the OEM metal gaskets from the rebuild kit. The question is whether to use also gasket sealer (high pressure/temperature) or not. The manual does not mention use of sealer so I thought I'd ask here for opinions.
SFD |
05-17-2011, 07:07 PM
I would put some on it..
to bad if it starts leaking 5 minutes after first start... ![]() '87 levin coupé ![]() |
05-18-2011, 01:14 AM
If you use the metal gaskets I´d put a litte sealant on it, as said before, you´ll definatly regret if your engine leaks after a few km´s...
05-18-2011, 12:40 PM
Guess I'll be using sealer then... Thanks guys!!
SFD |
05-19-2011, 05:03 PM
Just beware you don't use too much of the sealer.
It can damage, if the sealer goes on places you don't want to have it. http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
05-19-2011, 07:38 PM
fax0815 Wrote:put a litte sealant ![]() 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,817 |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 90,443 |
05-05-2019 04:03 AM Last Post: Rocker100 |
Air Cleaner Assembly | Hama86 | 7 | 9,747 |
10-29-2018 03:28 AM Last Post: Hama86 |
Horn assembly | Hama86 | 5 | 7,109 |
08-11-2018 07:06 PM Last Post: Bean |
BT head with ST block. | CHOPKIN2 | 6 | 7,543 |
02-06-2018 06:27 PM Last Post: mad.matt |
