Engine block assembly
05-17-2011, 03:21 PM
Quick request of opinions:
Would you use gasket sealer on the rear crankshaft cover and the oil pump assembly flanges (along with the OEM gaskets of course)?
Cheers!
SFD
05-17-2011, 03:25 PM
Depends if the surface is nice or not.
http://bruutt.blogspot.nl/
05-17-2011, 03:27 PM
Well, I have sanded the surfaces with fine grit paper, so they are pretty smooth...
SFD
05-17-2011, 05:49 PM
Scrape off the old gasket, get it sanded with 400, worked fine for me Smile
Are you using paper or metal gaskets? I never really trusted the metal ones if the surface wasn´t mint!
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
05-17-2011, 06:15 PM
Contact areas are prepared for assembly. I will be using the OEM metal gaskets from the rebuild kit. The question is whether to use also gasket sealer (high pressure/temperature) or not. The manual does not mention use of sealer so I thought I'd ask here for opinions.
SFD
05-17-2011, 07:07 PM
I would put some on it..
to bad if it starts leaking 5 minutes after first start... Wink
'87 levin coupé
[Image: AEU86 AE86 - Engine block assembly]
05-18-2011, 01:14 AM
If you use the metal gaskets I´d put a litte sealant on it, as said before, you´ll definatly regret if your engine leaks after a few km´s...
05-18-2011, 12:40 PM
Guess I'll be using sealer then... Thanks guys!!
SFD
05-19-2011, 05:03 PM
Just beware you don't use too much of the sealer.
It can damage, if the sealer goes on places you don't want to have it.
05-19-2011, 07:38 PM
fax0815 Wrote:put a litte sealant
Thumbs up!
  Question about 4AG 20v Engine Block CHACAMAN 1 1,589 06-10-2022 05:17 PM
  4AGE block differences explained (incl. some eyecandy) Bean 46 86,601 05-05-2019 04:03 AM
Last Post: Rocker100
  Air Cleaner Assembly Hama86 7 9,233 10-29-2018 03:28 AM
Last Post: Hama86
  Horn assembly Hama86 5 6,752 08-11-2018 07:06 PM
  BT head with ST block. CHOPKIN2 6 7,120 02-06-2018 06:27 PM
