Engine wont rev. Fuel pump?
02-15-2007, 04:17 PM
Re: Engine wont rev. Fuel pump?
max_ae86 Wrote:1) try to clean your sparks (happens to me)
2) To check is the fuel pump working, you just unplag fuel hose and try to turn the key. if the fuel is running, the pump should be fine.
Ok, I'll try to check these points.
domi Wrote:Are all your cilinders firing?
Yes, all cylinders are working. Just engine won't rev.
Thanx for suggestions.
White ae86 Levin
Messages In This Thread
Engine wont rev. Fuel pump? - Nookie - 02-14-2007, 07:48 PM
[] - domi - 02-15-2007, 08:03 AM
Re: Engine wont rev. Fuel pump? - max_ae86 - 02-15-2007, 09:46 AM
[] - Mux213 - 02-15-2007, 10:07 AM
[] - Alex - 02-15-2007, 11:57 AM
Re: Engine wont rev. Fuel pump? - Nookie - 02-15-2007 04:17 PM
[] - vladx_kc - 02-15-2007, 05:08 PM
Re: Engine wont rev. Fuel pump? - Nookie - 02-15-2007, 06:12 PM
[] - matt mead - 02-15-2007, 09:51 PM
[] - Mux213 - 02-15-2007, 10:38 PM
[] - domi - 02-16-2007, 08:05 AM
[] - jamiemirror - 02-16-2007, 06:10 PM
[] - dr.occa - 02-17-2007, 08:07 AM
[] - domi - 02-17-2007, 08:26 AM
[] - Mux213 - 02-17-2007, 12:02 PM
[] - Nookie - 02-19-2007, 03:46 PM
[] - jamiemirror - 02-19-2007, 04:39 PM
[] - oldeskewltoy - 02-19-2007, 06:36 PM
[] - Nookie - 02-27-2007, 05:53 PM
[] - oldeskewltoy - 02-27-2007, 06:19 PM
[] - Nookie - 02-27-2007, 07:10 PM
[] - AEsuperG - 02-27-2007, 08:31 PM
[] - oldeskewltoy - 02-28-2007, 03:15 AM
[] - domi - 02-28-2007, 07:59 AM
[] - Ivan141 - 02-28-2007, 06:34 PM
[] - Nookie - 03-14-2007, 05:52 PM
[] - Hopi - 03-14-2007, 07:42 PM
[] - Nookie - 03-15-2007, 01:01 AM
[] - banpei - 03-15-2007, 02:46 PM
[] - jamiemirror - 03-15-2007, 02:52 PM
  20v BT - which oil pump? Mylesmck 4 2,922 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 5,451 04-29-2022 05:45 AM
  fuel line hose from the pump Wikizz 4 6,178 10-16-2017 07:11 PM
Last Post: jdm86gtz
  Raising the rev limit on stock ECU fax0815 2 11,074 08-31-2015 02:04 PM
Last Post: gon
  4age 16v oem ecu rev limiter research ditn 18 28,802 06-22-2015 08:02 AM
Last Post: ditn
