Engine wont rev. Fuel pump?
02-14-2007, 07:48 PM
Hello.
Today I was driving my hachi to shop, and there were very little fuel in my car, it began to shake, etc... (because of lack of fuel) So i hardly got to fuel station, filled some fuel, started my car and noticed, that it won't rev. If I 'pump' (push very often) gas pedal, it revs to about 3-4k rpm, but if I release accelerator - engine's rpm's drops to about 500-600, and finally stops. Same situation when i push accelerator stronger, and hold it. ![]() ![]() ![]() What can be wrong/damaged? How to check is the fuel pump working? Maybe someone had similar problems? ![]() p.s. these problems started today. Never had same problems. I know, that when you run out of fuel, pump gets some air, but if you make engine running for few minutes everything becomes fine. White ae86 Levin |
02-15-2007, 08:03 AM
Are all your cilinders firing?
I had similar issues due to burnt ignition wire end that was skipping contact on and off. Check that, also take a peek at the spark plugs - if it did happen as you were running out of fuel and never went away - check if maybe a plug got ashed dead as it was running lean. My engine is still not revving up, my issue though is different, but i can say - i feel your pain man. Good luck! |
02-15-2007, 09:46 AM
Nookie Wrote:Hello. 1) try to clean your sparks (happens to me) 2) To check is the fuel pump working, you just unplag fuel hose and try to turn the key. if the fuel is running, the pump should be fine. Fun is not the straight line! |
02-15-2007, 10:07 AM
Could also be that because you drove on an almost empty gastank, the residue that build up on the bottom of the tank in years was sucked in and now your fuel filter is clogged... Though its not very likely (happened on my DeLorean twice but it uses a different pickup system then the hachi
![]() Also good chance your fuel pump is not working great anymore all though I would expect your car to idle just fine then.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
02-15-2007, 11:57 AM
Did you check the intake? Maybe it doesn't have enough air to breathe...
02-15-2007, 04:17 PM
max_ae86 Wrote:1) try to clean your sparks (happens to me) Ok, I'll try to check these points. domi Wrote:Are all your cilinders firing? Yes, all cylinders are working. Just engine won't rev. Thanx for suggestions. White ae86 Levin |
02-15-2007, 05:08 PM
I had the same problem. It was a fuel pump.
100€ solved the problem. Vladimir ![]() N/A for life... |
02-15-2007, 06:12 PM
max_ae86 Wrote:2) To check is the fuel pump working, you just unplag fuel hose and try to turn the key. if the fuel is running, the pump should be fine.Unpluged that hose, the fuel runs (this means, that pump is alive? still thinking, that it can be 'easily' damaged, or smt...). ![]() So, if the fuel pump is OK what can be broken more? As I said, all four clyinders are working, and these problems started after that "empty fuel tank" driving... ![]() ![]() More ideas? vladx_kc Wrote:I had the same problem. It was a fuel pump.Had you unpluged that fuel hose? Did the fuel ran? Did it broke because the car was driven with empty fuel tank? (sorry for a lot of questions, but i'm very nervous about my car ![]() White ae86 Levin |
02-15-2007, 09:51 PM
is it mis firing
02-15-2007, 10:38 PM
Nookie,
If the fuelpump no longer runs at full strength that could be your problem as well. It is possible to damage a fuelpump if you totally run out of fuel, but not likely. Maybe drive to another AE owner and see if you can swap your fuel pump to test? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
20v BT - which oil pump? | Mylesmck | 4 | 3,055 |
Fuel pump issue | DJexor | 11 | 5,780 |
fuel line hose from the pump | Wikizz | 4 | 6,260 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
Raising the rev limit on stock ECU | fax0815 | 2 | 11,208 |
08-31-2015 02:04 PM Last Post: gon |
4age 16v oem ecu rev limiter research | ditn | 18 | 29,185 |
06-22-2015 08:02 AM Last Post: ditn |
