Exhaust gets REALLY warm, mild 4AGE build running MS
03-14-2010, 10:39 PM
What might cause the exhaust to get really warm (glowing!) in just a few minutes? Judging from the plugs its running a bit rich. Timing seems to be stabil no matter how high the revs. We tried locking timing to 40 degrees btdc.
Then we suspected that the exhaust cam timing was way off but its fully open at a 105 degrees because of a thinner head gasket and no adjustable cam gears. Its running 262/258 degrees catcam with 9 mm lift btw. What the h*** is going on Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
03-14-2010, 10:45 PM
what excaust you use on your car?
http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
03-14-2010, 10:47 PM
The exhaust is stock...
03-15-2010, 03:07 AM
have you tried retarding the timing?
AE86 ex-daily |
03-15-2010, 03:45 AM
My car with the issue (living in china so Jan is trying to get it ready for Nurburgring Arpil 1st)
--------------------------------- ... and setting the ignition at fixed 40degrees before top caused no pinging even at low revs. The trigger angle has been set to 50degrees... In the MS Manual they warn about this as the MS should not have time enough to calculate and deliver the spark timing I have heard that some rubber on the belt wheel can be displaced hence moving the wheel markings out of sync with the crack...? - Niels[img name=]http://www.aeu86.org/files/ae/thumbs/t_ae86_ignition_109.jpg[/img][img name=]http://www.aeu86.org/files/ae/thumbs/t_ae86_ignition_109.jpg[/img] |
03-15-2010, 04:02 AM
what version of megatune are you using? as I can't find that spark setting window in mine...
BTW I'll be on the ring too over easter as always AE86 ex-daily |
03-15-2010, 05:06 PM
I'm pretty sure I run mine with "triggerangle=10" and "spark output inverted=no"
What is your physical setup pickup and ignition wise? Have you checked with a ignition lamp what the ignition actually is? '85 AE86 4AGE, '94 SW20 3SGTE, '83 KP61, 72' RA21 |
03-15-2010, 06:59 PM
Jeg ville sq nok lige prøve at snakke med René. Det lyder som om tændingen kommer alt for sent. Så tændingsbanker den jo ikke, men tænder først når stemplet er på vej ned og forbrændingen kommer alt for sent. Den skal jo tænde 10 grader før den når toppen.
Eller at udstødningsventilerne ikke lukker tæt. Kontroller ventilafstand og mål evt med en lækagetester. Den må ikke fise i udstødningen når alle ventiler er lukkede. Den kan jo også have brændt udstødningsventiler, men så har den nedsat kompression. Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
03-15-2010, 08:17 PM
As I wrote timing seems fine and we did check using an ignition lamp.
Jimmy: MSeren er ikke købt ved Rene, så det er ikke sikkert at det vil hjælpe. Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
03-15-2010, 08:31 PM
Hello Im Martin and are also working on the car while Niels is in China.
The Megatune program is version 2,25 p3 we have checked the timing with ignition lamp. and the real timing is identical with the map, and we have tried (as wrote before) to lock the ignition at 40 degrees and let engine run about 2500-3000 rpm same time checking with ignition lamp. but in few minutes the exhaust manifold is glowing. I have check the valve clearence and check valves for leak with air in spark plug holes and it seems okay. the cam timing is also okay. I have checked that the timming mark on the belt wheel is at right position when piston is in top. this is wird. http://www.bjerre-rally.dk |
7AGE Build | apardal | 5 | 705 |
08-02-2024 12:11 PM Last Post: apardal |
Warm start problem | DJexor | 5 | 2,181 |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,376 |
Running issues | sam3007 | 6 | 2,690 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,119 |
