FAO Beams gurus
10-16-2011, 01:03 PM
FAO Beams gurus
Hello everyone,
I'm in the process of finalizing the deal for my Beams swap (seller has a complete donor Altezza SXE10-AEFVF he's braking).
Now I've read a lot lately concerning the whole mechanical/physical side of the swap and although not an easy task I'm confident to have that covered.
What I plan to do is using the Altezza OEM ECU and cluster for my swap to make it a neat conversion. I know this is very difficult and apparently needs a lot of rewiring but this is something I'm good at. Unfortunately I'm lacking a lot of information what pieces out of the Altezza are necessary to do this.
Hopefully some of you can help me out in that matter, so I can tell my friend what to include out of the donor.
Obvious list so far: the ones with the ? I'm not sure how many there are and which are needed
- engine with all ancillaries incl. intake and exhaust manifold
- gearbox
- propshaft
- ECU
- ?engine harness
- ?engine bay main harness with fuse box etc...
- ?instrument panel harness
If I missed something please comment Smile
Thanks in advance
Bean
10-16-2011, 05:16 PM
FAO Beams gurus
just had a chat with my friend and he will chuck in the whole loom from the car, front to back, all labeled up nicely. So I guess that will do the trick.
any inputs still welcome Smile
10-16-2011, 09:08 PM
FAO Beams gurus
Hey Bean,
check Aram's topic about mounting the damn thing into the car. There are I believe another 2 guys on the forum running beams. I guess the electric part will be hard but more easy then getting the engine in in a correct way
10-16-2011, 09:46 PM
FAO Beams gurus
robokill Wrote:Hey Bean,
seen Arams (and assassins and papys) already and know them by hart - one thing I probably will do differently but can only say for sure once I have everything together is that I'll fab custom mounts on the engine side of things and keep the AE86 engine mounts - only concern would be that they are too close together but I have seen other build which solved it like this so should be possible. My main goal regarding mounting the engine is to give it the slant position it originally has and mount it as low as possible without endangering the sump or messing up the suspension geometry. I'm prepared for quite a bit of custom work so all should be good.
As I'll be getting the complete loom, thankfully labeled by friend wiring should be rather easy now. Will try to keep everything neat and use proper connectors wherever possible Smile
10-30-2011, 10:20 AM
FAO Beams gurus
Just an FYI, you don't need the cluster. You can make it work with the AE86 one if you want. I did Smile .
Also, the oil psi gauge is the same output and works directly with the stock gauge.
Andrew
10-30-2011, 10:23 AM
FAO Beams gurus
assassin10000 Wrote:Just an FYI, you don't need the cluster. You can make it work with the AE86 one if you want. I did Smile .
Andrew
this project is on ice for a while due to law restricions etc.
Anyway thanks for the info - when I can go ahead with my plan eventualy I want to install the TRD cluster with the rpm in the center, kind a like that a lot Smile
  Toyota KE70 3SGE Beams Swap - Axle reliability cke70 15 25,163 04-13-2014 12:49 PM
Last Post: Celica RA45
  Wanted: Link to Beams Blacktop engine manual pdf irishtwincam 7 8,637 01-03-2014 11:31 AM
Last Post: irishtwincam
  altezza beams to ae86 help needed jonny514mcl 3 4,335 07-14-2012 12:15 PM
Last Post: jonny514mcl
  Header + exhaust for Beams setup KD2229 8 12,553 10-03-2011 07:25 AM
Last Post: KD2229
  Front Anti Roll Bar for Beams Swap KD2229 5 6,137 09-20-2011 10:04 AM
Last Post: Aram
