Fender rolling
10-31-2004, 02:10 PM
Fender rolling
Does anyone have any experience with fender rolling?
I need to roll the inner lip of the front fenders because I'm having problems since I lowered the car. After installing the trueno front on senna's car he had the same problems. Trueno fenders have bigger lips however and I managed to bend it in a bit by hand. That solved his problem, so Í think rolling the fenders will help my car as well.
How did you guys solve this? My car is lowered 4cm's and I have stock 14" wheels with 195/60r14 tires.
10-31-2004, 04:50 PM
Fender rolling
Baseball bat between fender and wheel, SLOWLY roll the car forward (with it off ofcourse) and roll as neccicary
NOTE: This should really only be done while its hot outside, unless you have a heat gun. heat up the paint / metal a little bit so it'll stretch and roll easier.
10-31-2004, 05:16 PM
Fender rolling
I dont have a baseball bat...it's not a big sport in europe Smile
I'll see what I can think of. I might just cut the lip off altogether, but that leaves me with even more annoying rust-proofing to do.
10-31-2004, 05:34 PM
Fender rolling
Ivan, you could ask the Tokkie family Wink
They certainly got one for you Smile
10-31-2004, 07:04 PM
Fender rolling
I got a baseball bat for you.
10-31-2004, 10:53 PM
Fender rolling
The Doctor Wrote:Ivan, you could ask the Tokkie family Wink
Haha. Good one! Thumbs up!
Maybe JesseP has a hockeystick for you: he's from Bussum and when I lived in Hilversum Hockey was a populair sport in het Gooi. Wink
[Image: AEU86 AE86 - Fender rolling]
11-02-2004, 04:53 PM
Fender rolling
Now I REALLY need to get rid of that pesky lip. I'ma buy myself some fender flares or new fenders because the revolotion wheels are really coming close to the fenders. I have less trouble with sharp turns than I had before with the 195/60r14 tires, but long corners at fast speeds are now also a problem....weird. I might just grind off the front fender lip altogether. Rolling is more trouble, whilst cutting provides a little bit more space for the tires.
11-02-2004, 09:47 PM
Fender rolling
If you're planning on getting wide fender flares you might aswell try rolling the fenders first. If it goes wrong you can always cutting it away.
11-03-2004, 01:15 AM
Fender rolling
Yeah I know. I dont like the mounting method used for most fibreglass flares. You have to screw those on top, which is likely to rust. If I put fibreglass front fenders on then I would mold in wider flares for sure. The rear is not causing me any problems yet luckily.
For the moment I'm going with more springrate and rolled lip up front.
Here's a pic so you have an idea how far out the revolutions come:
11-03-2004, 10:56 AM
Fender rolling
Stiffen the springs kill the rebound :-) problem solved
  Question: Where I can find this fender flare? winchi.c 3 5,309 05-01-2011 09:58 AM
Last Post: Bentley
  fender holes measure HELP sergiocharged 11 11,309 12-24-2010 04:08 PM
Last Post: aussiefan
  I need some info about the plastic under the 2 front fender Mattolo 4 5,716 02-22-2010 01:28 PM
Last Post: Mattolo
  Golf Fender Flares for the AE86 (rabbit ??) gon 6 7,618 05-13-2009 08:53 AM
Last Post: robokill
  Fender & Rims Combination Serencebey 11 18,214 03-04-2009 11:04 PM
Last Post: Serencebey
