Finding TDC on a 7AGE
03-29-2013, 10:54 PM
I FINALLY got my hands on an assembled 7AGE and the owner allowed me to check TDC by using a piston stop. You CAN'T do cam timing... if you don't KNOW where TDC is......... well... here it is
[Image: AEU86 AE86 - Finding TDC on a 7AGE]
Above is TRUE TDC... as measured by using a piston stop. 2 teeth off AT the CRANK!
I always figured that Toyota changed the position of the TDC dot on the 7A oil pumps and crank timing pulley. I figured (correctly... in many cases) that people had no idea where true TDC was because they were using a 4AG timing pulley, and using a 7A reference........
Big Grin
Dan -
03-29-2013, 11:04 PM
ahh good one. This should be added to the info when building a 7age.
03-30-2013, 05:03 PM
Indeed valuable!
1986 Toyota Corolla AE86 Levin Kouki Coupe Panda White/Black
2002 Toyota MR2/MR-S T-Sport Blue Mica
  7AGE Build apardal 5 1,268 08-02-2024 12:11 PM
Last Post: apardal
  timingbelt 7age 20V!! slowboy2 3 7,218 06-21-2016 09:41 AM
Last Post: ditn
  7AGE to W58, cluth type? slowboy2 2 5,647 05-25-2013 01:37 PM
Last Post: slowboy2
  Need help finding an axle that can handle high hp/torque kevcov 5 6,751 04-17-2011 10:50 AM
Last Post: Prime86
  7age 16v compression Pif 1 4,826 10-12-2010 09:37 PM
Last Post: Pif
