timingbelt 7age 20V!!
03-19-2016, 03:19 PM
Hello,
i want to build a 7age 20V engine. i did it before, but never got time to put a timming belt on it. (sold the engine to fast) can anyone tel me what kind of timingbelt need to be fit to a 7age 20V? toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
06-20-2016, 01:42 PM
You can get the 944 belt to fit.... And also you can use the Renault Laguna....
06-21-2016, 09:35 AM
(06-20-2016 01:42 PM)pack Wrote: You can get the 944 belt to fit.... And also you can use the Renault Laguna.... I think the porsche or the laguna belts are totally wrong for a 20V 7age.. I've heard the 16V 4age belts fit the 20V 7age! The 20V timing gears are as close to each other (compared to 16V heads) as the 7A block taller then the 4A.. |
06-21-2016, 09:41 AM
Manon racing has the kit and nzd is cheap for moment
7AGE Build | apardal | 5 | 1,335 |
08-02-2024 12:11 PM Last Post: apardal |
Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 5,279 |
09-15-2013 01:08 AM Last Post: jondee86 |
7AGE to W58, cluth type? | slowboy2 | 2 | 5,683 |
05-25-2013 01:37 PM Last Post: slowboy2 |
Finding TDC on a 7AGE | oldeskewltoy | 3 | 6,367 |
03-30-2013 05:03 PM Last Post: asyrigos |
7age 16v compression | Pif | 1 | 4,849 |
10-12-2010 09:37 PM Last Post: Pif |
