Finding TDC on a 7AGE
03-29-2013, 10:54 PM
I FINALLY got my hands on an assembled 7AGE and the owner allowed me to check TDC by using a piston stop. You CAN'T do cam timing... if you don't KNOW where TDC is......... well... here it is
Above is TRUE TDC... as measured by using a piston stop. 2 teeth off AT the CRANK! I always figured that Toyota changed the position of the TDC dot on the 7A oil pumps and crank timing pulley. I figured (correctly... in many cases) that people had no idea where true TDC was because they were using a 4AG timing pulley, and using a 7A reference........ Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-29-2013, 11:04 PM
ahh good one. This should be added to the info when building a 7age.
03-30-2013, 05:03 PM
Indeed valuable!
1986 Toyota Corolla AE86 Levin Kouki Coupe Panda White/Black 2002 Toyota MR2/MR-S T-Sport Blue Mica |
7AGE Build | apardal | 5 | 990 |
08-02-2024 12:11 PM Last Post: apardal |
timingbelt 7age 20V!! | slowboy2 | 3 | 7,058 |
06-21-2016 09:41 AM Last Post: ditn |
7AGE to W58, cluth type? | slowboy2 | 3 | 5,542 |
05-25-2013 01:37 PM Last Post: slowboy2 |
Need help finding an axle that can handle high hp/torque | kevcov | 5 | 6,611 |
04-17-2011 10:50 AM Last Post: Prime86 |
7age 16v compression | Pif | 1 | 4,747 |
10-12-2010 09:37 PM Last Post: Pif |
