Finish Exhaust Martelius
01-15-2009, 11:07 AM
http://www.aeu86.org/viewtopic/ae86/t/59...sc/start=0
Quote:I think those parts give more torque from about 3000 rpm--> And my car was in "bench" and there was 135hp / 6850 rpm and torque was 153nm / 4200 rpm. "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
01-16-2009, 07:59 PM
Eircamae86 Wrote: Including shipments to the west coast of the USA?????? Hmmmmmmmm... shouldn't the piping be paired as 1 and 4 and then 2 and 3??? As the pic shows you will not get alternating pulses with the above arraignment Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-16-2009, 09:00 PM
That is the lastes version of 4age exhaust mani..
good stuff they are, and very good power output.. |
10-01-2010, 04:46 AM
Is this group buy still going on? If so im interested and just messaged your stores site. Looks like a great header
04-14-2012, 09:49 PM
BUMP FROM THE DEAD!
I know... I know.... HOWEVER, I only do it for good reasons Has anyone purchased and used this header yet? Maybe dyno'd it? I'm not too interested in HP figures, jus torque and drivability. Unless the HP completely tanks. Anyone? Wow, I could have sworn I had an account here... I guess I'm the new guy |
04-14-2012, 10:24 PM
I´ll fit mine next week and will get a dyno print later on.
04-14-2012, 11:25 PM
dazed_driver Wrote:BUMP FROM THE DEAD! I have it on mine 20v. if you are using your car as a daily, it's not the best header for you. At low revs the torque figure is terrible, but the power on high revs is impressive. It has different heat coating nowdays, it is now some black coating. The manager of Martelius told this to me when i bought the header and recommended this for daily drivers. http://www.martelius.com/index.php?modul...ct=490020C |
04-15-2012, 12:47 PM
Sidorifto Wrote:dazed_driver Wrote:BUMP FROM THE DEAD! did the manager of Martelius tell you upto what powerlevel the street header version will be good to? I considered this for quite a while but am woried that it'll kill my topend (will put out some 180hp +/-20) due to the "small" 50mm diameter ending. @fax: please keep us/me posted on this what are your power/torque relevant modifications? AE86 ex-daily |
04-15-2012, 12:59 PM
Bean, its easy to cut off the manifold at the last 2-1 collector and then knock a 2.25-2.5" pipe into an oval shape and weld it back together. You could also make a diffuser from the 50mm to a 60mm cross-section and might even pick up some power.
04-15-2012, 01:10 PM
NoHachi Wrote:Bean, its easy to cut off the manifold at the last 2-1 collector and then knock a 2.25-2.5" pipe into an oval shape and weld it back together. You could also make a diffuser from the 50mm to a 60mm cross-section and might even pick up some power. True but the primaries and secondaries still might be restrictive. Anyway let's wait for some result I'm in no rush. AE86 ex-daily |
Help me to finish!!! | Allexz | 9 | 7,835 |
02-10-2008 05:26 AM Last Post: parrot |
User(s) browsing this thread: 21 Guest(s)
