Firehawk's N2 racecar project
07-13-2006, 09:42 PM
Post: #51
Have you had any more luck with those clutch members? I just took apart an old zenki LSD that I had for spares, the clutch member holding the sattelite gears is also broken. Hopefully I wont find any of this type of damage in my own old LSD.. the one I want to rebuild.
07-14-2006, 03:17 PM
Post: #52
Ivan141 Wrote:Have you had any more luck with those clutch members? I just took apart an old zenki LSD that I had for spares, the clutch member holding the sattelite gears is also broken. Hopefully I wont find any of this type of damage in my own old LSD.. the one I want to rebuild.No, haven't had any luck yet. ![]() ![]() In the meanwhile, I've got plenty of time to work on the body - I reckon that all the rust repairs (sans the rear arches) and seam welding should be complete after this weekend. I still don't know what to use for repairing the rear arches, though (Irishtwincam, any word on those new Wolf Steel panels?).. |
07-21-2006, 02:48 PM
Post: #53
Ahh, finally managed to find a spare LSD - one of the side gears is cracked and has also worn out the planetary gears quite badly but fortunately the clutch members were still undamaged.
![]() I also managed to get my hands on a pretty rare Carrosser (aka Cusco) speedometer gear kit which changes the speedo gears to match a 4.625 final gear. It should make the speedo reading a bit more accurate when using the 4.778 final gear. Well, didn't quite get all the welding done but at least all the rust holes on the floorpan are now fixed. 80% of the spot welding is also done - there's a bit more work to do around the rear wheel wells. I added some new photos to the gallery; http://www.r5r.net/photo/v/projects/ae86...?g2_page=2 As soon as the floorpan and frame rails are finished, I'll paint them (using a brush to get the paint in every small gap) with some gray etching primer for rust protection. Then I can turn the car back upright and start working on the visible side. There's such a thick layer of paint on the car that it's probably best to strip everything that's visible down to bare metal before repainting. ![]() |
07-21-2006, 03:39 PM
Post: #54
jani,
in one of the other threads irishtwincam posted the rear wheel arch that is now available, 90$ if I am not mistaken but don't hold me to it ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
07-21-2006, 04:10 PM
Post: #55
Wow...nice finds..where did you find the lsd and speedo gear? yahoo japan?
07-21-2006, 05:22 PM
Post: #56
Ivan141 Wrote:Wow...nice finds..where did you find the lsd and speedo gear? yahoo japan?Actually, I got them both from here in Finland. ![]() http://www.rmf.fi/PC_Toyota.htm Photos of the parts are here (starting about halfway through the page): http://www.rmf.fi/RMF_HK_Kamat/Sivu1.html |
07-21-2006, 06:24 PM
Post: #57
Does he have more of those speedo kits? I just got my 4.5 r&p set, I wonder if toyota sells something that will work with the t50 for that end reduction.
BTW, all those pics just gave me a huge hard-on... what parts does he have for ae86's? FABRICA MI DIEM, PVNC! |
07-21-2006, 08:08 PM
Post: #58
can you give me the list for the K-series engine parts, i can see some of them, but i can't understand it
![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
07-21-2006, 08:44 PM
Post: #59
O MY GOD!
Those parts look fantastic!I like the original style rpm meter which goes to 10.000 RPM. ![]() Only costs 450 euro ![]() Real men race downhill |
07-21-2006, 09:41 PM
Post: #60
I made a quick'n'dirty translation to english of the parts list;
![]() http://www.r5r.net/tmp/PC_Toyota.htm The list may not be up-to-date, so email him ([email protected]) and ask whether some part is still available. |
ae86 racecar with beams engine | bakonick | 148 | 169,232 |
Racecar: TRD USA built ITA AE86 | oldeskewltoy | 38 | 44,708 |
07-22-2019 02:55 PM Last Post: apardal |
S.K.s AE86 racecar | S.K. | 207 | 229,354 |
09-18-2016 11:39 AM Last Post: totta Crolla |
Jonny's Levin Racecar | Jonny Rochester | 9 | 12,350 |
01-03-2010 04:34 PM Last Post: woper |
Another AE86 build up - Racecar | Jan Pedersen | 18 | 21,029 |
06-09-2008 03:34 PM Last Post: Jan Pedersen |
