Flywheel Weight?
03-08-2006, 08:29 AM
Flywheel Weight?
You've never seen the results of an exploding flywheel have you? I suspect it's not something that is guaranteed to go wrong, but if it does it will tear through the metal of your car like it's paper. Seen some pics of a honda where this happened....lets just say he's lucky it was a FWD car cause it could easily have taken a leg off otherwise.
03-11-2006, 03:36 PM
Flywheel Weight?
Heres a pic of my toda next to oem one. bling~!!! I think its around 3.7kg but haven't weighted it after the machine and balance. Its a forged moly...something which makes it safer than lightening oem.
Going in a few days! You can also consider ARP flywheel bolts for high rev. I just got toyota oem replacements as their meant to be very good with some locktite sealant. ![]() |
03-13-2006, 12:05 PM
Flywheel Weight?
Ivan141 Wrote:You've never seen the results of an exploding flywheel have you? I suspect it's not something that is guaranteed to go wrong, but if it does it will tear through the metal of your car like it's paper. Seen some pics of a honda where this happened....lets just say he's lucky it was a FWD car cause it could easily have taken a leg off otherwise. I saw the honda flywheel explode. Agree with Ivan, just buy real thing. Drifting - best fun you can have in your car with your pants on! |
AE86 rear axle weight | megabob | 11 | 19,734 |
light weight Flywheel | filh | 9 | 7,691 |
02-05-2018 05:20 PM Last Post: filh |
crank 6 bolt flywheel | DJexor | 5 | 8,409 |
12-05-2016 08:21 AM Last Post: d3nso |
Flywheel fitting | totta Crolla | 11 | 13,235 |
11-24-2013 05:31 PM Last Post: Apsogos |
Steering column weight savings? | 4000GT | 4 | 5,721 |
09-20-2012 08:40 PM Last Post: 4000GT |
