Flywheel and rpm
09-06-2006, 07:51 PM
Flywheel and rpm
To cut a long story short i have a MK1 mr2 4age in my cam, i put corolla clutch and flywheel onto this, just changed my clutch and flywheel back to the mr2 ones and my idle spedd has changed, its at 2500 rpm when cold and when hot 2000, i presume the different weights in flywheels is causing this, anyone else have similar issues at any stage and what did ye adjust?
09-06-2006, 11:47 PM
Flywheel and rpm
it should not affect it at all
its timing or somrthing of that nature Max [email protected] |
09-07-2006, 11:26 AM
Flywheel and rpm
I have never heard of changing flywheel affects idle. Usually a bigger cam or a different program in the ECU than the factory one makes difference.
Bigger camshaft makes idle unstable and different program gives higher idle. ![]() Toyota Corolla KE30 + Toyota Corolla AE86 |
09-07-2006, 11:32 AM
Flywheel and rpm
Did someone mess with the little idle screw on your throttle body? You know, the one that sets your idle?
Maybe just try and adjust your idle with it? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-07-2006, 05:42 PM
Flywheel and rpm
What different weights? I think they're much the same. Check your water system vacuum lines and idle adjustment screw. If you cant adjust it further down make sure the throttle is properly adjusted at the throttle body.
If that's all in order then you might have a problem with the coolant lines to the throttle body or perhaps the thermostat. FABRICA MI DIEM, PVNC! |
09-07-2006, 07:02 PM
Flywheel and rpm
Thanks for the help ill try a few things and let ye know how i get on, i also changed my starter cause it engaged itself while the car was running so maybe this has something to do with the problem.
09-08-2006, 07:24 PM
Flywheel and rpm
found out a vacum pipe near the battey had come, thanks for the help anyway.
09-14-2006, 08:04 AM
Flywheel and rpm
did you disconnect the battery? if you do the ecu can have problems with finding idle. and alsi ckeck youre throttle body, the inside can be dirty and this can give porblems with finding idle after disconnect the batt.
so clean throttlebody with brakecleaner and put the batt back on i think that can help. AE86 is a way of living and i like it sideways!! http://www.atectuning.nl |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,663 |
light weight Flywheel | filh | 9 | 7,596 |
02-05-2018 05:20 PM Last Post: filh |
crank 6 bolt flywheel | DJexor | 5 | 8,347 |
12-05-2016 08:21 AM Last Post: d3nso |
Bad vibrations /resonance starts at 5000 rpm | izanagi | 7 | 8,687 |
07-23-2015 05:02 PM Last Post: Bean |
Engine Check Light at High RPM | Super86 | 8 | 8,933 |
11-03-2014 11:03 AM Last Post: Super86 |
