Bad vibrations /resonance starts at 5000 rpm
07-23-2015, 12:18 AM
Hi all,
The car has vibrations/resonance that starts at 5000 rpm during acceleration and also deceleration.
I checked all (exhaust line, exhaust manifold, components) but no issue.
I was thinking of my TODA flywheel and exedy clutch but TODA says that the kit is balanced.
Please someone to help me.
Thanks
07-23-2015, 02:25 AM (This post was last modified: 07-23-2015 02:27 AM by oldeskewltoy.)
(07-23-2015 12:18 AM)izanagi Wrote:  I was thinking of my TODA flywheel and exedy clutch but TODA says that the kit is balanced.
Thanks
a friends Toda flywheel was close... but it used a tiny bit of balancing....
[Image: AEU86 AE86 - Bad vibrations /resonance s...t 5000 rpm]
the pressure plate(Toyota OEM part), on the other hand, was WAAAY out......
Dan -
07-23-2015, 06:42 AM
Just to have a bit more info are the vibrations the same regardless of which gear you're in?
07-23-2015, 09:36 AM (This post was last modified: 07-23-2015 09:36 AM by izanagi.)
Thanks
You think that the problem is my pressure plate ?
(07-23-2015 06:42 AM)Bean Bandit Wrote:  Just to have a bit more info are the vibrations the same regardless of which gear you're in?
In any gear and even in neutral.
07-23-2015, 09:57 AM
Thanks
If it happens as well with the clutch pressed it's a safe bet regarding flywheel/pressure plate
07-23-2015, 09:59 AM
Thanks
I didn't try with the clutch pedal pressed. Good idea.
07-23-2015, 11:30 AM
Thanks for your help. I just found the problem.
The fu*$#*@ vibration came from a small broken piece of metal from the end of my exhaust line.
07-23-2015, 05:02 PM
well that certainly wouldn't have been on top of my guess list. Glad you found it.
Sent from my SM-T800 using Tapatalk
  ClutchMaxPRO Clutches - Good or Bad? RolanTHUNDER 0 2,228 12-01-2022 09:55 AM
Last Post: RolanTHUNDER
  No idle below 2000 rpm rich running Steller Engineering 3 2,833 11-30-2022 02:45 PM
  Engine starts/revs but no idle GenkiMotors 17 11,587 11-20-2021 04:12 AM
Last Post: GenkiMotors
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 22,060 08-16-2018 01:36 AM
  Engine Check Light at High RPM Super86 8 10,752 11-03-2014 11:03 AM
Last Post: Super86
