Bad vibrations /resonance starts at 5000 rpm
07-23-2015, 12:18 AM
Hi all,
The car has vibrations/resonance that starts at 5000 rpm during acceleration and also deceleration. I checked all (exhaust line, exhaust manifold, components) but no issue. I was thinking of my TODA flywheel and exedy clutch but TODA says that the kit is balanced. Please someone to help me. Thanks |
07-23-2015, 02:25 AM
(This post was last modified: 07-23-2015 02:27 AM by oldeskewltoy.)
(07-23-2015 12:18 AM)izanagi Wrote: I was thinking of my TODA flywheel and exedy clutch but TODA says that the kit is balanced. a friends Toda flywheel was close... but it used a tiny bit of balancing.... ![]() the pressure plate(Toyota OEM part), on the other hand, was WAAAY out...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-23-2015, 06:42 AM
Just to have a bit more info are the vibrations the same regardless of which gear you're in?
AE86 ex-daily |
07-23-2015, 09:36 AM
(This post was last modified: 07-23-2015 09:36 AM by izanagi.)
(07-23-2015 02:25 AM)oldeskewltoy Wrote:You think that the problem is my pressure plate ?(07-23-2015 12:18 AM)izanagi Wrote: I was thinking of my TODA flywheel and exedy clutch but TODA says that the kit is balanced. (07-23-2015 06:42 AM)Bean Bandit Wrote: Just to have a bit more info are the vibrations the same regardless of which gear you're in?In any gear and even in neutral. |
07-23-2015, 09:57 AM
(07-23-2015 09:36 AM)izanagi Wrote:If it happens as well with the clutch pressed it's a safe bet regarding flywheel/pressure plate(07-23-2015 02:25 AM)oldeskewltoy Wrote:You think that the problem is my pressure plate ?(07-23-2015 12:18 AM)izanagi Wrote: I was thinking of my TODA flywheel and exedy clutch but TODA says that the kit is balanced. AE86 ex-daily |
07-23-2015, 09:59 AM
(07-23-2015 09:57 AM)Bean Bandit Wrote:I didn't try with the clutch pedal pressed. Good idea.(07-23-2015 09:36 AM)izanagi Wrote:If it happens as well with the clutch pressed it's a safe bet regarding flywheel/pressure plate(07-23-2015 02:25 AM)oldeskewltoy Wrote:You think that the problem is my pressure plate ?(07-23-2015 12:18 AM)izanagi Wrote: I was thinking of my TODA flywheel and exedy clutch but TODA says that the kit is balanced. |
07-23-2015, 11:30 AM
Thanks for your help. I just found the problem.
The fu*$#*@ vibration came from a small broken piece of metal from the end of my exhaust line. |
07-23-2015, 05:02 PM
well that certainly wouldn't have been on top of my guess list. Glad you found it.
Sent from my SM-T800 using Tapatalk AE86 ex-daily |
ClutchMaxPRO Clutches - Good or Bad? | RolanTHUNDER | 0 | 1,270 |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,691 |
Engine starts/revs but no idle | GenkiMotors | 17 | 8,082 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 18,145 |
Engine Check Light at High RPM | Super86 | 8 | 9,000 |
11-03-2014 11:03 AM Last Post: Super86 |
