Forged rods for 4AGE 20v options
07-07-2011, 07:43 AM
Its an NA application, with a bit more HP, I have seen the Brian Crower ones, they seem reasonably priced and are a bit lighter than stock, other options? I know Carrillo do them, but are insanely expensive, Pauter do as well, but are about the same weight as stock.
07-07-2011, 03:03 PM
orion engineered motorwerks (+EM) and T3 offer rods as well...
07-08-2011, 08:37 AM
4000GT Wrote:Its an NA application, with a bit more HP,...
Sarcasm? Insane RPM? If not, then you do not need anything aftermarket.
So what!
07-08-2011, 10:44 AM
Bean Bandit Wrote:orion engineered motorwerks (+EM) and T3 offer rods as well...
Thanks I saw that, I was looking at Tomei as well, they are reasonably priced at USD680, the Carrillo ones were USD380 each! Ill look up the Orion ones, never heard of them before...
07-08-2011, 10:49 AM
Ummm 10mm lift 288 Kelford cams, 1mm OS intake and exhaust valves and Supertech springs, 81.25mm custom 12:1 forged narrow skirt CP pistons, Toda cam gears (intake and exhaust), etc etc
I want a light motor to spin freely, so yes I need aftermarket, can save 400 grams going to forged rods.
07-12-2011, 10:30 AM
Not sure if you have ever seen these. I remember spool conrod's somewhere but bugger if i can remember where.
http://www.ebay.com.au/itm/ATTKD-ConRods...2a122cc819
http://www.ebay.com.au/itm/Toyota-4AGE-C...3f0360279f
Also if you have an engine like that then you know about the kilo's that can be saved in the flywheel and balancer.
Steve.....this is sparrrrrtan
07-12-2011, 12:49 PM
Using a stock blacktop fly and balancer actually... thought that were quite light as it is?
07-13-2011, 06:20 AM
Too my knowledge blacktop flywheel and balancer are the lightest of factory options although they are by no means the lightest available.
Many flywheel makers have them at around 3.9-4.1kgs v's blacktops 5.9kgs. Small port 7.1kg and bigports 7.9kgs i believe.
Balancer's i wouldn't know but ive seen alloy pulley kits that im sure would be lighter then the stock Toyota options.
Im also lead to believe that a balancer that is too light could harm the harmonics of the crank. I think the balances soul purpose is that stop/suppress the vibration cause by each combustion stoke.
Dont forget too that removing weight means less momentum to climb hills. Im mean sure it will free rev very well but wont climb in revs very well up hills.
http://www.my-acoustic.com/Car/weight_is...weight.htm
Other useful stuff in here.
07-13-2011, 08:30 AM
Interesting I see Toda do a 3.7kg version. I do wonder, can the 200mm flywheel and then a 200mm clutch fit the 20v (which is 212mm stock?) There is a 200mm Toda one come up cheap locally...
07-13-2011, 10:30 AM
yes any combination works i believe, its only the supercharged version 4agze that doesn't work, its alot bigger then the other 2, about 243mm or something around that mark.
The 200mm (bigport) and 212mm (small port and 20v's) are the same outside dimension flywheels its only the clutch cover and plate that differs, many go for the 212mm simply for the extra clutch surface area and potential extra clamping force.
Just make sure you order a clutch to suit the right size flywheel, not 100% sure if its possible to mix and match between the 200mm and 212mm.
  Bigger brake master cylinder options Koen Bongers 6 710 12-03-2025 02:01 PM
Last Post: r.ave
Thumbs Up ITB filter options mister86 1 4,504 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 34,592 07-28-2019 08:17 PM
Last Post: harkes
  AE86 rear suspension options 2018 Alex 9 14,139 01-24-2018 02:25 PM
  Rear axle options Dino86 13 17,096 01-08-2018 10:19 PM
Last Post: ditn
