Forged rods for 4AGE 20v options
07-13-2011, 10:41 AM
fkn16v Wrote:yes any combination works i believe, its only the supercharged version 4agze that doesn't work, its alot bigger then the other 2, about 243mm or something around that mark.
The 200mm (bigport) and 212mm (small port and 20v's) are the same outside dimension flywheels its only the clutch cover and plate that differs, many go for the 212mm simply for the extra clutch surface area and potential extra clamping force.
Just make sure you order a clutch to suit the right size flywheel, not 100% sure if its possible to mix and match between the 200mm and 212mm.
mix matching the two sizes doesn't work but can use both of the smaller ones on small, big, silver and blacktop. If you go for a uprated clutch flywheel combo you don't have to worry about clamping force etc as to be honest our little engines don't produce much torque in an NA setup i.e. Exedy Super Single will hold in excess of 200 Nm (twice then most tunes) of heavy abuse Wink
07-17-2011, 08:50 PM
You can use some Blacktop with upgrade rod bolts. This setup will do for 9-9500rpm. But I've seen some Blacktops blowing the engine because of the weak rods.
Go buy a complete Blacktop engine, switch the head with a smallport 16v, fit some Wiseco or JE high comp. pistons and fit the ITB's. Then you have the light bottom end, the light 212mm flywheel, the expensive ITB's and the best head for N/A for the cheapest price.
I have bought a set of Atlantic (Carillo) rods and pistons (JE), this are the lightest setup I can find, but the price is also in the high end.
But don't underestimate the cheap china rods, I know a few who run 10.000rpm with 2 bar of boost without problems Yummie!
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
Thumbs Up ITB filter options mister86 1 3,631 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 31,420 07-28-2019 08:17 PM
Last Post: harkes
  AE86 rear suspension options 2018 Alex 9 11,597 01-24-2018 02:25 PM
  Rear axle options Dino86 13 13,665 01-08-2018 10:19 PM
Last Post: ditn
  Gearbox and Diff options MIGGZFSU 35 29,711 03-26-2017 12:00 AM
Last Post: MIGGZFSU
