Front brake discs from another car?
09-14-2006, 05:37 PM
Hello there,
I have serious question: is there any car model, that's front brake discs would be exhactly the same as the ae86 Confused: Ae86 is very rare model here, in Lithuania, and i can't find those front brake discs Banging head
White ae86 Levin
09-14-2006, 05:57 PM
Nookie, try finding the discs you need on ebay... or find a company that imports a lot of carparts cause they can usually find what you need.
We have webshops that sell them in holland too..but it's cheaper to find them locally.
09-14-2006, 05:59 PM
asiliuk, taigi sakiau, kad galiu tau juo parupinti!!!
Big GrinBig Grin
eng: doode, i told you that i can source em to ya!!
adam
09-14-2006, 06:30 PM
i think ae86 disc can be aranged, at last from ebay.de.
But another question, what for disc to use with FC3S caliper if i not accept the measures of FC3S discs?
http://www.86ers.org
09-14-2006, 08:20 PM
I have been thinking lately about brakediscs. Wouldn't the old celica supra fit as well ?
09-14-2006, 11:00 PM
nope, i've got a set of Celica GTS (also 4A-GE) front brakes.
They are quite a lot bigger, but everything is different.
Could be a nice upgrade, but it's a lot of work, sadly.
[Image: AEU86 AE86 - Front brake discs from another car?]
09-18-2006, 11:59 AM
If you use the RXY 4pot calipers you need a special mounting bracket.
the discs are from an Integra Type R DC2 i think, thats what i run
Its gotta go whoosh or give a whine!!!!
09-18-2006, 12:10 PM
ITR discs are the same as the accord aerodeck VTEC..these are quite a lot cheaper usually.
09-18-2006, 12:13 PM
Yea but try buy a set of up rated after market aerodeck discs?
09-18-2006, 12:31 PM
You could try to use s13 discs(pump) mcphersons,knuckles. arms. tie rods. Its a lot of stuuf but when you done it you have a lot of negative camber better brakes.
KAE70--> http://www.youtube.com/watch?v=VJasjMGVd7k
Ae86 daily drift car rebuild
  Handbrake adjustment discs? DMC 8 2,057 03-10-2024 08:08 PM
Last Post: DMC
  Front big brake kit DidiDex 14 18,981 10-24-2016 09:29 AM
Last Post: FanIsHere
  Rear ae86 rear discs & pad part numbers? J-86 4 6,033 11-30-2012 06:32 PM
Last Post: J-86
  Toyota partnumbers OEM brake lines (front) IBMFD3S 6 7,482 01-10-2012 06:36 PM
Last Post: bozu
  Brake master cylinder for FC3S brake conversion Hachi Go 8 14,445 03-03-2011 12:06 AM
Last Post: filh
